15
I upgraded on a fresh install to Ubuntu 12.10, and I've tried installing wine many times, but I always get this:
This error could be caused by required additional software packages which are missing or not installable.
Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
wine:
It won't let me install the dependencies either it says it needs another set of dependencies to install them. Using Asus KJ50 64bit OS, dual boot with Windows 7
sudo apt-get install wine1.5
Reading package lists... Done
Building dependency tree
 wine1.5 : Depends: wine1.5-i386 (= 1.5.15-0ubuntu1) but it is not installable
           Recommends: gnome-exe-thumbnailer but it is not going to be installed or
                       kde-runtime but it is not going to be installed
           Recommends: ttf-droid
           Recommends: ttf-mscorefonts-installer but it is not going to be installed
           Recommends: ttf-umefont but it is not going to be installed
           Recommends: ttf-unfonts-core but it is not going to be installed
           Recommends: winbind but it is not going to be installed
           Recommends: winetricks but it is not going to be installed
Zanna
  • 72,312
RawX
  • 161
5 Answers5
12
I've been having the same issue, it turns out that with newer versions of apt and dpkg they support a feature called "Multi-arch". In simple terms, you can specify that apt pulls package info from repositories for architectures other than the native install, and install multiarch compatible packages from those repos. For more detailed information, see: http://wiki.debian.org/Multiarch/HOWTO
Your issue specifically, is that the wine1.5-i386 is in the 32 bit wine repository, but not in the 64 bit repo, and your dpkg/apt are not configured to deal with this for some reason. To resolve:
Check your native architecture with:
sudo dpkg --print-architecture #in your case this should return 'amd64'
Other available architectures can be shown by:
sudo dpkg --print-foreign-architectures #in your case this should not return anything
So you need to configure a new foreign architecture (quantal/12.10 or newer***):
sudo dpkg --add-architecture i386
Check your new arch is now available, update and install your package with apt:
sudo dpkg --print-foreign-architectures #now this should return 'i386'
sudo apt-get update; sudo apt-get install wine1.5 #and away you go!
***Note that the Ubuntu dpkg in natty (1.16.0~ubuntu7 (reports 1.15.8.10)), oneiric and precise (1.16.1.2ubuntu7) uses a different syntax:*
echo "foreign-architecture i386" > /etc/dpkg.cfg.d/architectures
cleary
  • 684
Did you follow this procedure when installing wine :
open the terminal and type thes commands: but first remove wine by the command : sudo apt-get remove --purge wine*
sudo add-apt-repository ppa:ubuntu-wine
after adding the wine reprository which you already did. Using the software manager go to ‘edit’ and choose ‘software sources’. Select the ‘other software’ tab and click on ‘add’ at the bottom of the window. You now need to add the following line of code instead of the original Wine PPA link.
deb http://ppa.launchpad.net/ubuntu-wine/ppa/ubuntu precise main
You can now close the sources list and the software manager. Next to update your sources list open up the Terminal and type:
sudo apt-get update
Once your sources list has been updated you can install either the stable 1.4 Wine package or the 1.5 development package using the following commands:
Wine 1.4 (stable)
sudo apt-get install wine1.4
Wine 1.5 (development)
That’s all there is to it, you will now also continue to get the latest Wine releases and updates on your Linux, enjoy!
source of the solution
another solution: How do I resolve unmet dependencies after adding a PPA?
Suhaib
  • 4,171
This is an error when trying to install the i386 package on a 64 bit install. try following this guide for your system!
http://wiki.winehq.org/WineOn64bit#head-77def7ca75193f24e358dba3dd6bcf674bd61b37
I know this because this is what I had originally done.
Matthew
It's not installable, because it depends on i386 architecture which isn't there in your system.
To add it, try:
update your apt repositories:
sudo apt-get update
and install wine again:
Alternatively you can --force-architecture by using dpkg.
kenorb
  • 10,944
-1
First I recommanded to remove wine with configuration files
sudo apt-get  --purge wine*
Update system and upgrade packages, Fix dependency
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install -f
Remove Unnecessary packages if any
sudo apt-get autoremove
Now Install wine
Clen cache
sudo apt-get clean
KK Patel
  • 19,753
