As already pointed out here, people seems to have issues with installing wine in the latest version of Ubuntu. I'm suspecting this only happens with 64 bit users.
For example, when trying to install wine or ia32-libs with apt-get, I get a lot of dependency errors. Doing a sudo apt-get -f install doesn't seem to do the trick, neither does using aptitude.
The errors I get is normally that the packages depend on some :i386 package, but installing those manually doesn't work either because they also have dependency issues (isn't APT supposed to do this automatically?!). I also downloaded CrossOver today and tried installing the .deb manually, but the dependency issues show up there as well. When running sudo apt-get -f install after trying to install the CrossOver .deb, apt-get wants to purge the following packages:
  • ia32-crossover
  • intel-gpu-tools
  • libdrm-nouveau2
  • libgl1-mesa-dri
  • libva-x11-1
  • ubuntu-desktop
  • vlc
  • xorg
  • xserver-xorg-video-ati
  • xserver-xorg-video-intel
  • xserver-xorg-video-modesetting
  • xserver-xorg-video-openchrome
  • xserver-xorg-video-radeon
  • xserver-xorg-video-vmware
What I've tried so far (and didn't work):
  • Installing synaptic, reloading my repositories, searching for ia32 and installing ia32-libs.
  • Using Ubuntu Software Center to install Wine and ia32-libs.
  • Using apt-get and aptitude to install all the differend varieties of the wine packages, both with and without the :i386 and -amd64 suffixes in package names.
  • Disabling the universe and multiverse repos, run a sudo apt-get update and then re-enable them again.
  • Boot a newly downloaded Ubuntu 12.10 x64 live USB and try to install all the different packages there.
What I've tried so far (that actually DID work):
  • Installing 12.10 x64 in VirtualBox and installing wine1.4-amd64.
What I haven't tried (yet):
  • Boot a newly downloaded Ubuntu 12.10 x32 image and try to install wine there (I'm just guessing that will work).
  • Reinstall Ubuntu.
  • Throw my computer out a window.
wine
alexander@cosmo:~$ LANGUAGE=en_US sudo apt-get install wine
Reading package lists... Done
Building dependency tree
 wine : Depends: wine1.5 but it is not going to be installed
wine-1.4
alexander@cosmo:~$ sudo apt-get install wine1.4
 wine1.4 : Depends: wine1.4-i386 (= 1.4.1-0ubuntu1)
ia32-libs
alexander@cosmo:~$ sudo apt-get install ia32-libs
 ia32-libs : Depends: ia32-libs-multiarch
carestad
  • 992
7 Answers7
Okay. So I found out what caused my problems. It was probably some PPAs with certain packages that created the dependency issues. While surfing randomly at Askubuntu last night, I came across an answer that fixed my problem.
Here is the answer, just modified so it works for Ubuntu 12.10:
First a downgrade is required and done with the following: create the 'preferences' file:
sudo vi /etc/apt/preferences
and insert the following lines:
Package: *
Pin: release a=quantal*
Pin-Priority: 2012
enter :wq to write the file. Pin-Priority must be greater than 1000.
Then you may downgrade the offending applications with:
sudo apt-get dist-upgrade
And that was it. Installing wine, crossover and ia32-libs now work. Why this happened when I ran a freshly downloaded 12.10 version of Ubuntu live I don't know and don't understand.
Thank you all for trying to help!
carestad
  • 992
This drove me crazy as well. I installed Ubuntu 64-bit using plain debootstrap from a 32-bit Ubuntu lucid (booting a newer 64-bit kernel).
After digging through forums and documentation I found out that I had to do:
dpkg --add-architecture i386
(actually I found a page on disabling multiarch and figured out that it was not enabled in the first place)
Radu
  • 51
I'm also using Ubuntu 12.10(64-bit), and I had installed both Wine and ia32-libs package without any problem.So this is not the problem of having 64-bit. You should try to install both "wine 1.4.1" and "Ia32 shared libraries - transitional package" through Ubuntu Software Center, like I did.
I faced the similar problem when installing Skype in 12.04 64bit.
I was stuck at the point where the ia32-libs was not installed and throws error message:
Cannot Install ia32-libs
Solution is to try to update all the repositories. I did it via Synaptic package manager.
Reload all the repositories and try to install wine. This may solve your problem.
It worked for me. After that there was no error in installing ia32-libs package or ia32-multarch-libs.
snoop
  • 4,110
  • 41
  • 58
s.m
  • 2,287
It seems you have multiple repositories in your APT sources list that contain wine packages. Combined with suboptimal APT preferences (defaults defined in /etc/apt/preferences) this can lead to installability problems. To fix these it might suffice to do the following.
sudo apt-get -t quantal install wine1.4
If this does not suffice then temporarily remove from your sources list references to alternative wine repositories. You may, for example, have a file /etc/apt/sources.list.d/ubuntu-wine-ppa-quantal.list whose contents look like the following.
deb     http://ppa.launchpad.net/ubuntu-wine/ppa/ubuntu quantal main
deb-src http://ppa.launchpad.net/ubuntu-wine/ppa/ubuntu quantal main
Comment these lines out and try again to install the wine1.4 package.
jdthood
  • 12,625
I found a fix for this and I hope it works for you. I simply installed first the GCC 4.7 multilib. After doing this, it seems WINE but first with a complaint about a broken package and after clicking apply again in Synaptic, it installs.
I first installed:
gcc-4.7-multilib g++-4.7-multilib gobjc++-4.7-multilib gobjc-4.7-multilib
What I think happens is that during the installation of the multilib dev tools, it executes the correct command to configure the system to accept the i386 WINE libs that it requires. WINE is 32bit by default but I install both the 32bit and AMD64 and it seems to work great. My games play really smooth. I'm very happy with 12.10 + WINE + nVidia drivers.
Good luck!
It seems your current architecture is amd64 (dpkg --print-architecture), so you've to add i386 to the list of architectures for which packages can be installed without using --force-architecture.
So the full solution how to install wine, it would be
sudo dpkg --add-architecture i386
sudo add-apt-repository -y ppa:ubuntu-wine
sudo apt-get update
sudo apt-get install wine # or wine1.7
kenorb
  • 10,944
