I am running Ubuntu and trying to install Wine. When I run sudo apt-get install wine, it gives the following error:
 wine : Depends: wine1.4 but it is not going to be installed
I have tried using the -f flag and this doesn't help. Ubuntu software centre returns a similar error.
Edit: Here is what is returned when trying to run sudo apt-get install wine1.4:
$ sudo apt-get install wine1.4
Reading package lists... Done
Building dependency tree
 wine1.4 : Depends: wine1.4-i386 (= 1.4.1-0ubuntu1) but it is not installable
           Recommends: gnome-exe-thumbnailer but it is not going to be installed or
                       kde-runtime but it is not going to be installed
           Recommends: ttf-droid
           Recommends: ttf-mscorefonts-installer but it is not going to be installed
           Recommends: ttf-umefont but it is not going to be installed
           Recommends: ttf-unfonts-core but it is not going to be installed
           Recommends: winbind but it is not going to be installed
           Recommends: winetricks but it is not going to be installed
microbug
  • 247
Try this file from WineHQ and run it as root or with the sudo command
  1. Download the dependency build file from here.
  2. Copy and paste it into a gedit and save it with a .sh extension
  3. Open terminal and run it as root i.e:
    sudo sh filename.sh
Seth
  • 59,332
Zuko
  • 1,277
