401
I've installed a version of Java. How can we set the $JAVA_HOME environment variable correctly?
kiri
  • 28,986
You can set your JAVA_HOME in /etc/profile as Petronilla Escarabajo suggests. But the preferred location for JAVA_HOME or any system variable is /etc/environment.
Open /etc/environment in any text editor like nano or gedit and add the following line:
JAVA_HOME="/usr/lib/jvm/open-jdk"
(java path could be different)
Use source to load the variables, by running this command:
source /etc/environment
Then check the variable, by running this command:
echo $JAVA_HOME
Update
Usually most linux systems source /etc/environment by default. If your system doesn't do that add the following line to ~/.bashrc (Thanks @pje)
Zanna
  • 72,312
88
To set JAVA_HOME environment variable, do the following:
  1. Launch Terminal by pressing Ctrl+Alt+T on your keyboard.
  2. Enter the following command:
    $ gksudo gedit /etc/environment
  3. Depending on where you installed your Java, you will need to provide the full path. For this example, I installed Oracle JDK 7 in the /usr/lib/jvm/java-7-oracle directory.
    Scroll to the end of the file and enter the following:
    JAVA_HOME=/usr/lib/jvm/java-7-oracle
    export JAVA_HOME
  4. Save your file and exit gedit.
  5. Lastly, reload the system PATH with the following command:
    $ . /etc/environment
The above method will save you the hassle in having to run the commands every time you log in to your computer.
52
If you do not know the path and you only have openJDK installed, you can type update-alternatives --config java and you should find the path. To set the variable you can write JAVA_HOME=<PATH> followed by export JAVA_HOME. Notice there's no space when declaring the variable. To check if the variable is stored you simply type echo $JAVA_HOME to verify.
Erro
  • 899
This is the best option if you always want to use the latest one installed.
Nowadays (Ubuntu 23.10) you should probably have it installed through apt like:
sudo apt install default-jdk # or default-jre
In this case, you should find it at /usr/lib/jvm/default-java.
It's a symlink that points to whichever the current JVM is on the same folder.
So, just run this to add the environment as a separate file:
sudo nano /etc/environment.d/90java.conf
Add this line and save:
JAVA_HOME="/usr/lib/jvm/default-java"
Then reboot or login again, or source /etc/environment.d/90java.conf to load it on the current shell.
geekley
  • 697
