Primary topic:
Please help me with a problem encountered in attempt to begin Android project in Eclipse. Please note that I want to use Eclipse and not to install another IDE.
Secondary:
I want to know if this Eclipse/Android environment has this many bugs in daily use as well. Only (yes, only) if this is the case I would want to know what practical solution is there to develop Android applications on a low-profile Ubuntu PC.
Problem:
Ran New Android project wizard in Eclipse first time after install of the Android SDK plug-in.
After it was completed, the following message appeared:
Errors occurred during the build. Errors running builder 'Android Resource Manager' on project 'pr1Android'. java.lang.NullPointerException
From the log file:
Failed to load properties file for project 'pr1Android'
Problems occurred when invoking code from plug-in:
org.eclipse.core.resources.java.lang.NullPointerException at com.android.ide.eclipse.adt.internal.build.builders.BaseBuilder.abortOnBadSetup(BaseBuilder.java:327) at com.android.ide.eclipse.adt.internal.build.builders.ResourceManagerBuilder.build(ResourceManagerBuilder.java:92) at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239) at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295) at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351) at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374) at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143) at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Circumstance:
Ubuntu 16.04, java 1.8.0_91
New install of Android SDK and plug-in for Eclipse
Passed all stages of tutorial of user Casper Ll in: Complete Installation Guide for Android SDK / ADT Bundle on Ubuntu
An error at step 7 of the tutorial was solved following the instructions of user kolim in the following: https://android.stackexchange.com/questions/145437/reinstall-avd-on-ubuntu-16-04/145690 it includes to install lib64stdc++6
