204
Setting up keys for a local repository on a new ubuntu 20.10 virtual machine, I got a message that apt-key add was deprecated and I should read the apt-key(8) man page. The apt-key(8) man page is a collection of words strung together, but if it contains information I can't winkle it out. Can anyone tell me what, exactly, I should type on my terminal instead of:
apt-key add name-of-file
The command does apparently still work after honking at me, so I was able to proceed, but would like to know what I'll need to do in the future.
david6
  • 14,528
  • 38
  • 46
user1160711
  • 2,597
8 Answers8
339
You need to know why apt-key add is deprecated
All of the answers so far work around the symptom ("Don't use apt-key add") but fail to address the actual problem that led to apt-key add being deprecated. The problem is not a question of appending a key to one big keyring file etc/apt/trusted.gpg vs manually putting single-key keyring files into the directory /etc/apt/trusted.gpg.d/. These two things are equivalent, and doing either one is a huge security risk.
The problem is that any key you add to either of the above is completely and unconditionally trusted by apt. This means that when installing any package from any repo (including the official distro repos), apt will happily accept the package being signed by any of those trusted keys (whether the key belongs to the repository the package is coming from or not). This weakens the assurance provided by the package signing mechanism against malicous packages being injected into the official Ubuntu mirrors network.
What we want to do instead is configure apt to accept signatures from a third-party repository only on packages being installed from that repository — no cross-signing. Apt's default pinning rules give higher priority to official distro repos, which (in conjunction with proper key management) offers some protection against third-party repos replacing distro-provided packages. (At least, I think that's default. You can use apt-cache policy to inspect the current pin priorities, and if needed you can adjust pinning based on origin to achieve this effect. See man apt_preferences for details.)
The instructions given in Ugo Delle Donne's answer for converting the key to the (legacy) keyring v4 format that apt will accept are correct and helpful, but that's only half of the solution. I'll reiterate them here (cleaned up slightly) so all the steps are consolidated in one place:
  • Download the key:
    • wget https://host.domain.tld/path/to/<keyfile>.<ext>
      (No need for -O or >; wget defaults to saving the file in your current directory with the same filename it has on the server.)
  • Verify that the filetype is "PGP public key block Public-Key (old)":
    • file <keyfile>.<ext>
  • gpg supports a number of key formats, so if your key is in a different format, convert it by importing it into a temp keyring, then exporting it again:
    • gpg --no-default-keyring --keyring ./temp-keyring.gpg --import <keyfile>.<ext>
    • gpg --no-default-keyring --keyring ./temp-keyring.gpg --export --output <your-keyfile-name>.gpg
    • rm temp-keyring.gpg
Now that you have your converted key, do not add it to apt's trusted keystore by copying it into /etc/apt/trusted.gpg.d/. Instead, put it somewhere like /etc/apt/keyrings/. (You might need to create that keyrings directory first.) There's nothing special about that location, it's just a convention recommended by man 5 sources.list in Ubuntu 22.04 and a related Debian Wiki entry.
At this point, nothing has changed and apt doesn't know the key exists. The last step is to modify the specific .list file for the repository to tell apt where to find the key for that specific repo.
  • Edit the file /etc/apt/sources.list.d/<example>.list, and in between deb and the url, add [signed-by=/etc/apt/keyrings/<your-keyfile-name>.gpg]
Now apt will accept that key's signature for all packages in that repo and only that repo.
Notes:
  • If you already have keyring files in /etc/apt/trusted.gpg.d/, you can copy move them to /etc/apt/keyrings/ as-is, and then update all the corresponding .list files so each one has a signed-by field pointing to its own key.
  • If you already have keys in the /etc/apt/trusted.gpg keyring file beyond the official repo keys, this answer details the steps to locate and remove them. You can then follow all the same steps above to set them up the safer way. (Exporting them from that keyring is also possible, but the exact steps are left as an exercise for the reader.)
  • To import a repo's key from a keyserver to a standalone file:
    • gpg --no-default-keyring --keyring <output-file-name>.gpg --keyserver <some.keyserver.uri> --recv-keys <fingerprint>
    • This should give you a key that apt will accept without conversion.
  • Apt is still very trusting, and a malicious or compromised repo can bypass this measure easily because packages currently can run arbitrary shell code as root in their setup scripts. Closing off one attack vector doesn't hurt, though, and progress is (slowly) being made on other fronts.
  • Optionally, you can switch to the newer, more verbose Deb822 format using individual .sources files instead of .list files. It's more work, but personally I find the result far more readable.
Sources:
MestreLion
  • 20,726
Askeli
  • 3,535
16
I stumbled on the same problem and luckily some other question lighted the way. In my example I was trying to add a teamviewer repository to a recent Kali linux and I was being blocked by the key verification.
I'm quite sure there's a more elegant way to do this but the following steps helped me fix the problem:
  1. Download the relevant key
    wget -O - https://download.teamviewer.com/download/linux/signature/TeamViewer2017.asc > ~/teamviewer.key
  2. Verify the type of file
    file ~/teamviewer.key
    it should be PGP public key block Public-Key (old)
  3. Create a keyring
    gpg --no-default-keyring --keyring ./teamviewer_keyring.gpg --import teamviewer.key
  4. This file is still not a valid key that can be added to /etc/apt/trusted.gpg.d/ since it's a keyring, but from the keyring we can extract the key with
    gpg --no-default-keyring --keyring ./teamviewer_keyring.gpg --export > ./teamviewer.gpg
  5. This file is the key you want to move to the trusted key folder
    sudo mv ./teamviewer.gpg /etc/apt/trusted.gpg.d/
happy sudo apt update!!!
13
The reason for this deprecation is because using apt-key add simply appends the gpg key to the trusted global APT keyring. It's similar to the preferred method of adding local_repo.list to /etc/apt/sources.list.d/ instead of using add-apt-repository dep /link/to/repo version, which appends the message to the global sources.list file.
I think it's a bit more awkward to understand than using the .d folder, but essentially we want to get the gpg key into a standalone keyring file, then point to this keyring file in the source listing. The default keyring file location is /usr/share/keyrings, and it can be a .asc or .gpg file. I'm not sure the difference but I do know the global keyring files are binary files, not plaintext.
For example:
Using generic names can be a bit hard to understand sometimes, so here is an example of installing mongoDB:
Get the MongoDB gpg key and add it to a new keyring file
curl https://www.mongodb.org/static/pgp/server-4.2.asc | sudo tee -a /usr/share/keyrings/buster-mongodb-org-4_2.asc
Add a source entry for apt, pointed to this new keyring.
For example, if your repository file is located at /etc/apt/sources.list.d/mongodb-org-4_2.list run the following command to add the keyfile:
echo "deb [signed-by=/usr/share/keyrings/buster-mongodb-org-4_2.asc] https://repo.mongodb.org/apt/debian buster/mongodb-org/4.2 main" | sudo tee /etc/apt/sources.list.d/mongodb-org-4_2.list
Install mongodb from this newly added repo
sudo apt install -y mongodb-org
Reference
This is still new to me, but most of what I know came from this excellent answer in the unix SE
mchid
  • 44,904
  • 102
  • 162
11
I created a shell script that can download and install keys to be used with [signed-by=] declaration in sources.list.
It's available on github.com/ameinild/add-apt-key.
POSIX Script for installing APT keys
General help
This script will help with installing PGP keys for APT repositories.
This script supports up to 2 arguments:
  • 1st argument is input file. This can be either:
    • An URL - key will be downloaded into current path (using wget or curl)
    • A filename - reads an existing key in current path
    • A path and a filename - reads an existing key in given path
  • 2nd argument is key output path and output name. This can be either:
    • Only filename - output path is set in config, saved as given filename
    • A path and a filename - output path is given here, saved as given filename
    • Only a path (end with /) - output path is given here, filename is taken from existing key
    • Empty - output path is set in config, filename is taken from existing key
This script has a config file /usr/local/etc/add-apt-key.conf, where the following variables can be set:
  • keypath : path to store converted key - default is /etc/apt/keyrings
  • verbosity : if set to Yes - displays extra output
  • removetmp : if set to Yes - remove input (non-converted) file
Example 1: (PWD=/root)
sudo add-apt-key https://mariadb.org/mariadb_release_signing_key.asc /usr/share/keyrings/
Will download key in /root, convert it and store as /usr/share/keyrings/mariadb_release_signing_key.gpg
Example 2: (PWD=/home/user)
sudo add-apt-key /root/mariadb_release_signing_key.asc /usr/share/keyrings/mariadbkey
Will use existing key in /root, convert it and store as /usr/share/keyrings/mariadbkey.gpg
Example 3: (PWD=/home/user)
sudo add-apt-key mariadb_release_signing_key.asc mariadbkey
Will use existing key in /home/user, convert it and store as /etc/apt/keyrings/mariadbkey.gpg
After installing the PGP key, it is also possible to add the key and repository to /etc/apt/sources.list
  • The choice to add this will be presented in the script as the first input option
  • If Yes is chosen, the repository string must be pasted as the second input option
This completes the key installation by adding the corresponding repository line to /etc/apt/sources.list
Installation
Install by running the following commands:
sudo curl -L https://raw.githubusercontent.com/ameinild/add-apt-key/master/add-apt-key -o /usr/local/bin/add-apt-key
sudo curl -L https://raw.githubusercontent.com/ameinild/add-apt-key/master/add-apt-key.conf -o /usr/local/etc/add-apt-key.conf
sudo chmod a+rx /usr/local/bin/add-apt-key
Artur Meinild
  • 31,035
UPDATE: 2023-Nov-15, Back in August, a PR I submitted to the apt-manage project was accepted, it includes a quick-install script which will install apt-manage on Debian and Ubuntu and their derivitives.
Once again, I've modified my answer below, replacing the installation with the quick-install script.
UPDATE: 2023-May-16, I can confirm apt-manage is the safest most consistent way I found to manage apt sources with keys properly.
I've rewritten the answer, removing my personal script (you can view it in the revisions history if you'd like) to focus on the command and not my personal code.
All of the answers here are great, and I've learned a lot from them.
Per @mesterlion comments, as of this time there is a single tool that does all of this, and does it correctly, properly maintained by the Pop!_OS team.
That tool is apt-manage which is part of RepoLib module which introduced the key sub-command in version 2.
So in Pop!_OS 22.04, installation will look like this:
sudo apt install --yes apt-manage
The upstream projects (Ubuntu and Debian) are missing this package, for that: the apt-manage project has a quick-install script (full disclosure, I submitted the PR for it).
Installing will look like:
curl https://raw.githubusercontent.com/pop-os/repolib/HEAD/quick-install.sh | bash
More details can be found in the Installation section of the git-repo's README.md.
Example 1
After installing apt-manage, below is an example of a set of calls from my system:
# Adding PPA
sudo apt-manage add --terse --format=sources ppa:ppa:alessandro-strada/ppa
Adding APT source and assinging a key
sudo apt-manage add --terse --format=sources --name Microsoft --identifier packages-microsoft-com 'deb [arch=amd64] https://packages.microsoft.com/ubuntu/22.04/prod jammy main'
Assigning a key via URL
sudo apt-manage key packages-microsoft-com --url=https://packages.microsoft.com/keys/microsoft.asc
R-Project needed some additional love - because they do something "different":
sudo apt-manage add --terse --format=sources --name R-Project --identifier cloud-r-project-org 'deb [arch=amd64] https://cloud.r-project.org/bin/linux/ubuntu jammy-cran40/ ""_""'
Specific to R-Project, as one of the values are empty and the command line can't pass it effectively.
sudo sed -i /etc/apt/sources.list.d/cloud-r-project-org.sources -Ee 's/""_""//g'
Assigning a key via fingerprint
sudo apt-manage key cloud-r-project-org --fingerprint=E298A3A825C0D65DFD57CBB651716619E084DAB9
After all were added, run update.
sudo apt update
Example 2: Initialize docker on a fresh Ubuntu compute instance
set -e
export DEBIAN_FRONTEND=noninteractive
apt-get update
&& apt-get install --yes --no-install-recommends
apt-transport-https ca-certificates
wget gnupg software-properties-common lsb-release
curl jq bash-completion
has() { command -v "$1" > /dev/null; }
Try differnt ways of installing apt-manage
First let's hope there is package ready for installation
has apt-manage
If the repo isn't part of existing apt sources, add it
REPO_URL="https://download.docker.com/linux/ubuntu" APT_NAME="$( apt-manage list -a
| grep -B4 "${REPO_URL}" | head -1
| sed -Ee 's/^\W*([^:]+):$/\1/' )" if [[ -n "${APT_NAME}" ]]; then >&2 printf '%s\n'
"$(apt-manage list "${APT_NAME}")"
"Docker repository found [${APT_NAME}]. Skipping." else apt-manage add --identifier download-docker-com --name Docker
"$( printf "deb [arch=%s] %s %s %s"
"$(dpkg --print-architecture)"
"${REPO_URL}"
"$(lsb_release --codename --short)"
"stable" )"
apt-manage key download-docker-com \
    --url=https://download.docker.com/linux/ubuntu/gpg
fi
As a direct workalike, replace apt-key add with gpg --dearmor:
curl [KEYURL] | sudo gpg --dearmor --yes -o /etc/apt/trusted.gpg.d/[KEYFILE].gpg
However, this is not recommended (other than as a workalike to apt-key) since all keys in the trusted directory are unconditionally trusted; it is better to put the output in a (non-globally) trusted directory (as others have suggested), and have each source specify which key(s) to trust, individually.
nyet
  • 238
Keys for use by apt are stored in /etc/apt/trusted.gpg.d/. apt-key managed these keyrings for you, but now that it's deprecated you need to choose a suitable file name <KEYRING> for the keyring yourself.
If you have the key already as a local file <FILE>, run
gpg --no-default-keyring --keyring=gnupg-ring:/etc/apt/trusted.gpg.d/<KEYRING>.gpg --import <FILE>
To directly read the key from <URL>, run
curl -sSfL <URL> | gpg --no-default-keyring --keyring=gnupg-ring:/etc/apt/trusted.gpg.d/<KEYRING>.gpg --import
Note: the prefix gnupg-ring: before the keyring name is required to create the keyring in the apt compatible (legacy) v4 format, rather than the (newer) keybox v1 format.
kynan
  • 2,235
If you have the *.asc file you can just --dearmor it
curl https://packages.microsoft.com/keys/microsoft.asc | gpg --dearmor > microsoft.gpg
install -o root -g root -m 644 microsoft.gpg /etc/apt/trusted.gpg.d/
MortenB
  • 111
