I want to install the Debian package for Chromium ( from Linux Mint) instead of the Snap one offered for Xubuntu, because the Snap version does not work with KeePassXC. The Debian version from the Mint maintainers does work (al least it worked well with Xubuntu 20.04). I tried to install Chromium as a Debian package following the instructions from How to install Chromium from the Linux Mint repositories in Ubuntu?.
I issued these commands (neglecting that apt-key has become deprecated as it adds a key to /etc/apt/trusted.gpg by default which causes security risks):
$ echo "deb http://packages.linuxmint.com victoria upstream" | sudo tee /etc/apt/sources.list.d/mint-victoria.list
$ sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com A1715D88E1DF1F24 40976EAF437D05B5 3B4FE6ACC0B21F32 A6616109451BBBF2 # meanwhile a deprecated utility!
$ sudo apt update
$ cat <<EOF | sudo tee /etc/apt/preferences.d/pin-chromium
Package: *
Pin: release o=linuxmint
Pin-Priority: -1
Package: chromium Pin: release o=linuxmint Pin-Priority: 1000 EOF
These ones all went flawlessly. The next one made problems:
$ LC_ALL=C sudo apt install chromium
Reading package lists... Done
Building dependency tree... Done
The following NEW packages will be installed:
  chromium
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/102 MB of archives.
After this operation, 323 MB of additional disk space will be used.
(Reading database ... 223159 files and directories currently installed.)
Preparing to unpack .../chromium_121.0.6167.139~linuxmint1+virginia_amd64.deb ...
Unpacking chromium (121.0.6167.139~linuxmint1+virginia) ...
dpkg: error processing archive /var/cache/apt/archives/chromium_121.0.6167.139~linuxmint1+virginia_amd64.deb (--unpack):
 trying to overwrite '/usr/share/applications/chromium-browser.desktop', which is also in package chromium-browser 1:85.0.4183.83-0ubuntu2.22.04.1
(this is a repetition of the command to show English error messages, originally 102 MB were fetched).
The file /var/cache/apt/archives/chromium_121.0.6167.139~linuxmint1+virginia_amd64.deb exists. To assure that it came right, I manually downloaded another copy from http://packages.linuxmint.com/pool/upstream/c/chromium/chromium_121.0.6167.139~linuxmint1+virginia_amd64.deb and compared it to the other one: Their content was identical. Nevertheless, I get this error message if I repeat sudo apt install chromium. How to proceed?
Adalbert Hanßen
  • 823
  • 15
  • 31
The comment gave the right hint: dpkg -l showed that there was some kind of chromium-browser installed (originally from the live stick):
$ dpkg -l | grep chromium
ii  chromium-browser                         1:85.0.4183.83-0ubuntu2.22.04.1 amd64
Transitional package - chromium-browser -> chromium snap
$ chromium-browser --version
Command '/usr/bin/chromium-browser' requires the chromium snap to be installed. Please install it with: snap install chromium # this is what I want to avoid! $
So this package was merely a stub to install the snap version which I wanted to avoid! After I removed it by sudo apt-get purge chromium-browser everything went fine (but I still used the deprecated command apt-key which will loose this function in future versions because it creates a security issue.):
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
Executing: /tmp/apt-key-gpghome.DsWBHBRTjv/gpg.1.sh --recv-keys --keyserver keyserver.ubuntu.com A1715D88E1DF1F24 40976EAF437D05B5 3B4FE6ACC0B21F32 A6616109451BBBF
gpg: "A6616109451BBBF" ist keine Schlüssel-ID: überspringe
gpg: Schlüssel 3B4FE6ACC0B21F32: "Ubuntu Archive Automatic Signing Key (2012) <ftpmaster@ubuntu.com>" nicht geändert
gpg: Schlüssel 40976EAF437D05B5: "Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.com>" nicht geändert
gpg: Schlüssel A1715D88E1DF1F24: "Launchpad PPA for Ubuntu Git Maintainers" nicht geändert
gpg: Anzahl insgesamt bearbeiteter Schlüssel: 3
gpg:              unverändert: 3
$ sudo apt update
OK:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
OK:2 https://linux.teamviewer.com/deb stable InRelease
OK:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
OK:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
OK:5 https://ppa.launchpadcontent.net/atareao/atareao/ubuntu jammy InRelease
OK:6 https://ppa.launchpadcontent.net/giuspen/ppa/ubuntu jammy InRelease
OK:7 https://ppa.launchpadcontent.net/yktooo/ppa/ubuntu jammy InRelease
Ign:8 http://packages.linuxmint.com una InRelease
OK:9 http://security.ubuntu.com/ubuntu jammy-security InRelease
Ign:10 http://packages.linuxmint.com victoria InRelease
OK:11 http://packages.linuxmint.com una Release
OK:12 http://packages.linuxmint.com victoria Release
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
Alle Pakete sind aktuell.
W: http://packages.linuxmint.com/dists/una/Release.gpg: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
W: http://packages.linuxmint.com/dists/victoria/Release.gpg: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
Package: *
Pin-Priority: -1
Package: chromium Pin: release o=linuxmint Pin-Priority: 1000 EOF Package: * Pin: release o=linuxmint Pin-Priority: -1 Package: chromium Pin: release o=linuxmint Pin-Priority: 1000 $ sudo apt install chromium Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt: gimp-help-common Verwenden Sie »sudo apt autoremove«, um es zu entfernen. Die folgenden NEUEN Pakete werden installiert: chromium 0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen noch 0 B von 102 MB an Archiven heruntergeladen werden. Nach dieser Operation werden 323 MB Plattenplatz zusätzlich benutzt. (Lese Datenbank ... 217914 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../chromium_121.0.6167.139~linuxmint1+virginia_amd64.deb ... Entpacken von chromium (121.0.6167.139~linuxmint1+virginia) ... chromium (121.0.6167.139~linuxmint1+virginia) wird eingerichtet ... Trigger für desktop-file-utils (0.26-1ubuntu3) werden verarbeitet ... Trigger für hicolor-icon-theme (0.17-2) werden verarbeitet ... Trigger für gnome-menus (3.36.0-1ubuntu3) werden verarbeitet ... Trigger für libc-bin (2.35-0ubuntu3.6) werden verarbeitet ... Trigger für man-db (2.10.2-1) werden verarbeitet ... Trigger für mailcap (3.70+nmu1ubuntu1) werden verarbeitet ... $ sudo apt autoremove Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Die folgenden Pakete werden ENTFERNT: gimp-help-common 0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert. Nach dieser Operation werden 23,6 kB Plattenplatz freigegeben. Möchten Sie fortfahren? [J/n] J (Lese Datenbank ... 218003 Dateien und Verzeichnisse sind derzeit installiert.) Entfernen von gimp-help-common (2.10.0-1) ... $
(sorry, I have forgotten to prepend the commands to get English messages).
Finally I got Version 121.0.6167.139 (Offizieller Build) for Linux Mint (64-Bit) this way.
There are several answers to my other question deprecated use of apt-key, which was a duplicate: What commands (exactly) should replace the deprecated apt-key?.
Bingo! (except for still using the deprecated command apt-key this post, starting at the headline "Install the Chromium Deb package from Linux Mint Repository [Requires effort]" describes a way downloading the LinuxMint key ring. However it is offered there only at an insecure http connection which I consider as yet another security risk. At least one would need some https-site of linuxmint.com which at least offers to verify the fingerprints of the keys in the key ring after downloading them, I suppose!)
Adalbert Hanßen
  • 823
  • 15
  • 31
