I have been using ubuntu 18.04 for quite a while now and it was working fine until this morning when I turned my pc on and used terminal for updates.
This is the output of sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
libuchardet0 lollypop-portal mpv phantomjs python3-bs4 python3-html5lib
python3-lxml python3-pylast python3-pyxattr python3-webencodings rtmpdump
youtube-dl
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
26 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up python3 (3.6.5-3ubuntu1) ...
running python rtupdate hooks for python3.6...
E: py3compile:183: cannot create directory /usr/share/hplip/ui5/__pycache__: FileNotFoundError(2, 'No such file or directory')
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/deviceuricombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr_ext.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabgrouptable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabnametable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/filetable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/loadpapergroupbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printernamecombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettings_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingstoolbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/queuesconf.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/readonlyradiobutton.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systemtray.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/ui_utils.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog_base.py'
error running python rtupdate hook hplip-data
dpkg: error processing package python3 (--configure):
installed python3 package post-installation script subprocess returned error exit status 4
dpkg: dependency problems prevent configuration of update-notifier-common:
update-notifier-common depends on python3:any; however:
Package python3 is not configured yet.
dpkg: error processing package update-notifier-common (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of idle:
idle depends on python3 (>= 3.6.5-3ubuntu1); however:
dpkg: error processing package idle (--configure):
dpkg: dependency problems prevent configuration of python3-update-manager:
python3-update-manager depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-update-manager (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of python3-dev:
python3-dev depends on python3 (= 3.6.5-3ubuntu1); however:
dpkg: error processing package python3-dev (--configure):
dpkg: dependency problems prevent configuration of gnome-shell:
gnome-shell depends on python3; however:
dpkg: error processing package gnome-shell (--configure):
dpkg: dependency problems prevent configuration of netplan.io:
netplan.io depends on python3; however:
dpkg: error processing package netplan.io (--configure):
dpkg: dependency problems prevent configuration of nplan:
nplan depends on netplan.io; however:
Package netplan.io is not configured yet.
dpkg: error processing package nplan (--configure):
dpkg: dependency problems prevent configuration of update-notifier:
update-notifier depends on update-notifier-common (= 3.192.1.3); however:
Package update-notifier-common is not configured yet.
dpkg: error processing package update-notifier (--configure):
dpkg: dependency problems prevent configuration of unattended-upgrades:
unattended-upgrades depends on python3; however:
dpkg: error processing package unattended-upgrades (--configure):
dpkg: dependency problems prevent configuration of idle3:
idle3 depends on python3 (>= 3.6.5-3ubuntu1); however:
idle3 depends on idle (>= 3.6.5-3ubuntu1); however:
Package idle is not configured yet.
dpkg: error processing package idle3 (--configure):
dpkg: dependency problems prevent configuration of update-manager:
update-manager depends on update-notifier; however:
Package update-notifier is not configured yet.
update-manager depends on policykit-1-gnome | polkit-kde-agent-1 | lxpolkit | lxqt-policykit | mate-polkit | polkit-1-auth-agent; however:
Package policykit-1-gnome is not installed.
Package polkit-kde-agent-1 is not installed.
Package lxpolkit is not installed.
Package lxqt-policykit is not installed.
Package mate-polkit is not installed.
Package polkit-1-auth-agent is not installed.
Package gnome-shell which provides polkit-1-auth-agent is not configured yet.
dpkg: error processing package update-manager (--configure):
dpkg: dependency problems prevent processing triggers for gnome-menus:
gnome-menus depends on python3:any (>= 3.1~); however:
dpkg: error processing package gnome-menus (--configure):
dependency problems - leaving triggers unprocessed
dpkg: dependency problems prevent configuration of update-manager-core:
update-manager-core depends on python3:any (>= 3.2~); however:
update-manager-core depends on python3-update-manager (= 1:18.04.11.3); however:
Package python3-update-manager is not configured yet.
dpkg: error processing package update-manager-core (--configure):
dpkg: dependency problems prevent processing triggers for gconf2:
gconf2 depends on python3:any; however:
dpkg: error processing package gconf2 (--configure):
dpkg: dependency problems prevent configuration of gdm3:
gdm3 depends on gnome-shell (>= 3.19.92); however:
Package gnome-shell is not configured yet.
dpkg: error processing package gdm3 (--configure):
dpkg: too many errors, stopping
python3
idle
python3-dev
gnome-shell
netplan.io
nplan
update-notifier
unattended-upgrades
idle3
update-manager
gnome-menus
update-manager-core
gconf2
gdm3
Processing was halted because there were too many errors.
I found another post, but i can't comment on that without asking a question myself so here is my problem. help would be appreciated. I also ran apt-cache policy hplip as was asked in the other post and got the same result.
]hplip:
Installed: 3.17.10+repack0-5
Candidate: 3.17.10+repack0-5
Version table:
*** 3.17.10+repack0-5 500
500 http://in.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
100 /var/lib/dpkg/status
