I installed Linux kernel for Ubuntu 16.04 64 bit as described here.
After 17 days of use, I started to get System crashes at the startup, which logs I sent to developers.
I do where same output also for sudo apt-get upgrade
masi@masi:~$ sudo apt-get update
[sudo] password for masi:
Hit:1 http://archive.ubuntu.com/ubuntu xenial InRelease
Get:23 http://archive.ubuntu.com/ubuntu xenial-security/universe amd64 DEP-11 Metadata [2,327 B]
Fetched 1,861 kB in 2s (707 kB/s)
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
I do but it starts to setup Linux 4.4 there too about which I am not sure
masi@masi:~$ sudo dpkg --configure -a
Setting up linux-tools-4.4.0-28 (4.4.0-28.47) ...
Setting up runit (2.1.2-3ubuntu1) ...
start: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
dpkg: error processing package runit (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up linux-image-4.4.0-28-generic (4.4.0-28.47) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
initrd.img(/boot/initrd.img-4.4.0-28-generic
) points to /boot/initrd.img-4.4.0-28-generic
(/boot/initrd.img-4.4.0-28-generic) -- doing nothing at /var/lib/dpkg/info/linux-image-4.4.0-28-generic.postinst line 491.
vmlinuz(/boot/vmlinuz-4.4.0-28-generic
) points to /boot/vmlinuz-4.4.0-28-generic
(/boot/vmlinuz-4.4.0-28-generic) -- doing nothing at /var/lib/dpkg/info/linux-image-4.4.0-28-generic.postinst line 491.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.0-28-generic /boot/vmlinuz-4.4.0-28-generic
run-parts: executing /etc/kernel/postinst.d/dkms 4.4.0-28-generic /boot/vmlinuz-4.4.0-28-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.4.0-28-generic /boot/vmlinuz-4.4.0-28-generic
update-initramfs: Generating /boot/initrd.img-4.4.0-28-generic
run-parts: executing /etc/kernel/postinst.d/pm-utils 4.4.0-28-generic /boot/vmlinuz-4.4.0-28-generic
run-parts: executing /etc/kernel/postinst.d/unattended-upgrades 4.4.0-28-generic /boot/vmlinuz-4.4.0-28-generic
run-parts: executing /etc/kernel/postinst.d/update-notifier 4.4.0-28-generic /boot/vmlinuz-4.4.0-28-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 4.4.0-28-generic /boot/vmlinuz-4.4.0-28-generic
Searching for GRUB installation directory ... found: /boot/grub
Searching for default file ... found: /boot/grub/default
Testing for an existing GRUB menu.lst file ...
Could not find /boot/grub/menu.lst file. Would you like /boot/grub/menu.lst generated for you? (y/N) y
Searching for splash image ... none found, skipping ...
Found kernel: /boot/memtest86+.bin
Found kernel: /boot/vmlinuz-4.6.0-040600-generic
Found kernel: /boot/vmlinuz-4.4.0-28-generic
Found kernel: /boot/vmlinuz-4.4.0-24-generic
Updating /boot/grub/menu.lst ... done
Setting up linux-tools-4.4.0-28-generic (4.4.0-28.47) ...
Setting up linux-headers-generic (4.4.0.28.30) ...
Setting up linux-image-extra-4.4.0-28-generic (4.4.0-28.47) ...
Testing for an existing GRUB menu.lst file ... found: /boot/grub/menu.lst
dpkg: dependency problems prevent configuration of git-daemon-run:
git-daemon-run depends on runit; however:
Package runit is not configured yet.
dpkg: error processing package git-daemon-run (--configure):
dependency problems - leaving unconfigured
Setting up linux-image-generic (4.4.0.28.30) ...
Setting up linux-tools-virtual (4.4.0.28.30) ...
Setting up linux-generic (4.4.0.28.30) ...
Setting up linux-generic-lts-utopic (4.4.0.28.30) ...
runit
git-daemon-run
Output of uname -r is 4.6.0-040600-generic.
Hardware: Macbook Air 2013-mid
System: Ubuntu 16.04 64 bit
Linux kernel: 4.6
Linux kernel options: wl
Reason for 4.6 Linux kernel: lid-suspend problem in 4.4, fixed much in 4.6
