When I install QGIS-ltr version in ubuntu 22.04, the following error pops out and I have tried every solution previously given but of no use.
Setting up qgis-providers (1:3.34.3+36jammy) ... /usr/lib/qgis/crssync: error while loading shared libraries: libpdal_util.so.13: cannot open shared object file: No such file or directory dpkg: error processing package qgis-providers (--configure): installed qgis-providers package post-installation script subprocess returned error exit status 127 dpkg: dependency problems prevent configuration of qgis: qgis depends on qgis-providers (= 1:3.34.3+36jammy); however: Package qgis-providers is not configured yet.
dpkg: error processing package qgis (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of qgis-plugin-grass: qgis-plugin-grass depends on qgis (= 1:3.34.3+36jammy); however: Package qgis is not configured yet.
dpkg: error processing package qgis-plugin-grass (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of python3-qgis: python3-qgis depends on qgis-providers (= 1:3.34.3+36jammy); however: Package qgis-providers is not configured yet.
dpkg: error processing package python3-qgis (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup error from a previous failure. No apport report written because the error message indicates its a followup error from a previous failure. No apport report written because MaxReports is reached already Errors were encountered while processing: qgis-providers qgis qgis-plugin-grass python3-qgis E: Sub-process /usr/bin/dpkg returned an error code (1)
Override the version conflict::
  1. sudo ln -s /usr/lib/libpdal_base.so.15 /usr/lib/libpdal_base.so.13
  2. sudo ln -s /usr/lib/libpdal_util.so.15 /usr/lib/libpdal_util.so.13
  3. sudo ldconfig
  4. Retry your installation
Daniel T
  • 5,339
