I want to install lamp in my Ubuntu 16.04. I use this website: :https://www.digitalocean.com/community/tutorials/how-to-install-linux-apache-mysql-php-lamp-stack-on-ubuntu-16-04. After installing apache and mysql when try to install php by using the below command sudo apt-get install php libapache2-mod-php php-mcrypt php-mysql I get the following results:
[sudo] password for pseudo:
Reading package lists... Done
Building dependency tree
Note, selecting 'libhttp-message-perl' for task 'lamp-server'
Note, selecting 'libencode-locale-perl' for task 'lamp-server'
Note, selecting 'libapache2-mod-php' for task 'lamp-server'
Note, selecting 'rename' for task 'lamp-server'
Note, selecting 'php-common' for task 'lamp-server'
Note, selecting 'libaprutil1' for task 'lamp-server'
Note, selecting 'libcgi-fast-perl' for task 'lamp-server'
Note, selecting 'libwrap0' for task 'lamp-server'
Note, selecting 'libhttp-date-perl' for task 'lamp-server'
Note, selecting 'perl-modules-5.22' for task 'lamp-server'
Note, selecting 'liblwp-mediatypes-perl' for task 'lamp-server'
Note, selecting 'libfcgi-perl' for task 'lamp-server'
Note, selecting 'libcgi-pm-perl' for task 'lamp-server'
Note, selecting 'libaprutil1-dbd-sqlite3' for task 'lamp-server'
Note, selecting 'libaio1' for task 'lamp-server'
Note, selecting 'libio-html-perl' for task 'lamp-server'
Note, selecting 'ssl-cert' for task 'lamp-server'
Note, selecting 'libperl5.22' for task 'lamp-server'
Note, selecting 'libapr1' for task 'lamp-server'
Note, selecting 'libaprutil1-ldap' for task 'lamp-server'
Note, selecting 'libhtml-tagset-perl' for task 'lamp-server'
Note, selecting 'tcpd' for task 'lamp-server'
Note, selecting 'liblua5.1-0' for task 'lamp-server'
Note, selecting 'libhtml-template-perl' for task 'lamp-server'
Note, selecting 'libtimedate-perl' for task 'lamp-server'
Note, selecting 'perl' for task 'lamp-server'
Note, selecting 'php-mysql' for task 'lamp-server'
Note, selecting 'libhtml-parser-perl' for task 'lamp-server'
Note, selecting 'liburi-perl' for task 'lamp-server'
libaio1 is already the newest version (0.3.110-2).
libapache2-mod-php is already the newest version (1:7.0+35ubuntu6).
libapr1 is already the newest version (1.5.2-3).
libaprutil1 is already the newest version (1.5.4-1build1).
libaprutil1-dbd-sqlite3 is already the newest version (1.5.4-1build1).
libaprutil1-ldap is already the newest version (1.5.4-1build1).
libcgi-fast-perl is already the newest version (1:2.10-1).
libcgi-pm-perl is already the newest version (4.26-1).
libencode-locale-perl is already the newest version (1.05-1).
libfcgi-perl is already the newest version (0.77-1build1).
libhtml-parser-perl is already the newest version (3.72-1).
libhtml-tagset-perl is already the newest version (3.20-2).
libhtml-template-perl is already the newest version (2.95-2).
libhttp-date-perl is already the newest version (6.02-1).
libhttp-message-perl is already the newest version (6.11-1).
libio-html-perl is already the newest version (1.001-1).
liblua5.1-0 is already the newest version (5.1.5-8ubuntu1).
liblwp-mediatypes-perl is already the newest version (6.02-1).
libperl5.22 is already the newest version (5.22.1-9).
libtimedate-perl is already the newest version (2.3000-2).
liburi-perl is already the newest version (1.71-1).
libwrap0 is already the newest version (7.6.q-25).
perl is already the newest version (5.22.1-9).
perl-modules-5.22 is already the newest version (5.22.1-9).
php-common is already the newest version (1:35ubuntu6).
php-mysql is already the newest version (1:7.0+35ubuntu6).
rename is already the newest version (0.20-4).
ssl-cert is already the newest version (1.0.37).
tcpd is already the newest version (7.6.q-25).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
9 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up php7.0-common (7.0.22-0ubuntu0.16.04.1) ...
dpkg: error processing package php7.0-common (--configure):
subprocess installed post-installation script returned error exit status 10
dpkg: dependency problems prevent configuration of php7.0-json:
php7.0-json depends on php7.0-common (= 7.0.22-0ubuntu0.16.04.1); however:
Package php7.0-common is not configured yet.
dpkg: error processing package php7.0-json (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of php7.0-opcache:
php7.0-opcache depends on php7.0-common (= 7.0.22-0ubuntu0.16.04.1); however:
dpkg: error processing package php7.0-opcache (--configure):
dpkg: dependency problems prevent configuration of php7.0-readline:
php7.0-readline depends on php7.0-common (= 7.0.22-0ubuntu0.16.04.1); however:
dpkg: error processing package php7.0-readline (--configure):
dpkg: dependency problems prevent configuration of php7.0-cli:
php7.0-cli depends on php7.0-common (= 7.0.22-0ubuNo apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
php7.0-cli depends on php7.0-json; however:
Package php7.0-json is not configured yet.
php7.0-cli depends on php7.0-opcache; however:
Package php7.0-opcache is not configured yet.
php7.0-cli depends on php7.0-readline; however:
Package php7.0-readline is not configured yet.
dpkg: error processing package php7.0-cli (--configure):
dpkg: dependency problems prevent configuration of libapache2-mod-php7.0:
libapache2-mod-php7.0 depends on php7.0-cli; however:
Package php7.0-cli is not configured yet.
libapache2-mod-php7.0 depends on php7.0-common (= 7.0.22-0ubuntu0.16.04.1); however:
libapache2-mod-php7.0 depends on php7.0-json; however:
libapache2-mod-php7.0 depends on php7.0-opcache; however:
dpkg: error processing package libapache2-mod-php7.0 (--configure):
dpkg: dependency problems prevent configuration of libapache2-mod-php:
libapache2-mod-php depends on libapache2-mod-php7.0; however:
Package libapache2-mod-php7.0 is not configured yet.
dpkg: error processing package libapache2-mod-php (--configure):
dpkg: dependency problems prevent configuration of php7.0-mysql:
php7.0-mysql depends on php7.0-common (= 7.0.22-0ubuntu0.16.04.1); however:
dpkg: error processing package php7.0-mysql (--configure):
dpkg: dependency problems prevent configuration of php-mysql:
php-mysql depends on php7.0-mysql; however:
Package php7.0-mysql is not configured yet.
dpkg: error processing package php-mysql (--configure):
php7.0-common
php7.0-json
php7.0-opcache
php7.0-readline
php7.0-cli
libapache2-mod-php
php7.0-mysql
php-mysql
I uninstall it and try to again reinstall it, but every time I got these errors. I can't understand what I should do.
karel
  • 122,292
  • 133
  • 301
  • 332
