I tried to install aircrack-ng and got following errors:
shiv@shiv-Inspiron-3542:~$ sudo -i apt-get install aircrack-ng
Reading package lists... Done
Building dependency tree
aircrack-ng is already the newest version (1:1.2-0~rc4-4).
The following packages were automatically installed and are no longer required:
  python3-ipython-genutils python3-jupyter-core python3-traitlets
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
16 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up python3 (3.6.5-3ubuntu1) ...
running python rtupdate hooks for python3.6...
E: py3compile:183: cannot create directory /usr/share/hplip/ui5/__pycache__: FileNotFoundError(2, 'No such file or directory')
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/deviceuricombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr_ext.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabgrouptable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabnametable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/filetable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/loadpapergroupbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printernamecombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettings_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingstoolbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/queuesconf.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/readonlyradiobutton.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systemtray.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/ui_utils.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog_base.py'
error running python rtupdate hook hplip-data
dpkg: error processing package python3 (--configure):
 installed python3 package post-installation script subprocess returned error exit status 4
dpkg: dependency problems prevent configuration of python3-update-manager:
 python3-update-manager depends on python3:any (>= 3.3.2-2~); however:
  Package python3 is not configured yet.
dpkg: error processing package python3-update-manager (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of python3-dev:
 python3-dev depends on python3 (= 3.6.5-3ubuntu1); however:
dpkg: error processing package python3-dev (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
                   No apport report written because MaxReports is reached already
        dpkg: dependency problems prevent configuration of netplan.io:
 netplan.io depends on python3; however:
dpkg: error processing package netplan.io (--configure):
dpkg: dependency problems prevent configuration of nplan:
 nplan depends on netplan.io; however:
  Package netplan.io is not configured yet.
dpkg: error processing package nplan (--configure):
                                                              dpkg: dependency problems prevent configuration of update-manager:
dpkg: error processing package update-manager (--configure):
                                                              dpkg: dependency problems prevent processing triggers for gnome-menus:
 gnome-menus depends on python3:any (>= 3.1~); however:
dpkg: error processing package gnome-menus (--configure):
 dependency problems - leaving triggers unprocessed
                                                              dpkg: dependency problems prevent configuration of update-manager-core:
 update-manager-core depends on python3:any (>= 3.2~); however:
 update-manager-core depends on python3-update-manager (= 1:18.04.11.3); however:
  Package python3-update-manager is not configured yet.
dpkg: error processing package update-manager-core (--configure):
                                                              dpkg: dependency problems prevent processing triggers for gconf2:
 gconf2 depends on python3:any; however:
dpkg: error processing package gconf2 (--configure):
dpkg: too many errors, stopping
 python3
 python3-dev
 netplan.io
 nplan
 update-manager
 gnome-menus
 update-manager-core
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
 gconf2
Processing was halted because there were too many errors.
abu_bua
  • 11,313
Try to install with this command (w/o -i):
sudo apt-get install aircrack-ng
Maybe you have first to remove it with
sudo apt-get purge aircrack-ng
N0rbert
  • 103,263
abu_bua
  • 11,313
