I had a problem on 18.04. It seems the system never updated since I installed it in March, because of a Heroku "failing" package/repo. (sorry for wrong wording but I am new to Ubuntu)
Now my system has fully updated (Firefox, Thunderbird ..) and Software and updates are up-to-date.
Also my system seems stable and everything seems to work.
However, sudo apt-get -f install gives the following errors:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
41 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up python3 (3.6.5-3ubuntu1) ...
running python rtupdate hooks for python3.6...
E: py3compile:183: cannot create directory /usr/share/hplip/ui5/__pycache__: FileNotFoundError(2, 'No such file or directory')
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/deviceuricombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr_ext.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabgrouptable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabnametable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/filetable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/loadpapergroupbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printernamecombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettings_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingstoolbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/queuesconf.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/readonlyradiobutton.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systemtray.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/ui_utils.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog_base.py'
error running python rtupdate hook hplip-data
dpkg: error processing package python3 (--configure):
installed python3 package post-installation script subprocess returned error exit status 4
dpkg: dependency problems prevent configuration of update-notifier-common:
update-notifier-common depends on python3:any; however:
Package python3 is not configured yet.
dpkg: error processing package update-notifier-common (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of python3-commandnotfound:
python3-commandnotfound depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-commandnotfound (--configure):
dpkg: dependency problems prevent configuration of python3-pyqt5:
python3-pyqt5 depends on python3 (<< 3.7); however:
python3-pyqt5 depends on python3 (>= 3.6~); however:
python3-pyqt5 depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-pyqt5 (--configNo apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
ure):
dpkg: dependency problems prevent configuration of language-selector-common:
language-selector-common depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package language-selector-common (--configure):
dpkg: dependency problems prevent configuration of python3-xdg:
python3-xdg depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-xdg (--configure):
dpkg: dependency problems prevent configuration of python3-update-manager:
python3-update-manager depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-update-manager (--configure):
dpkg: dependency problems prevent configuration of gnome-shell:
gnome-shell No apport report written because MaxReports is reached already
depends on python3; however:
dpkg: error processing package gnome-shell (--configure):
dpkg: dependency problems prevent configuration of apport-gtk:
apport-gtk depends on python3; however:
dpkg: error processing package apport-gtk (--configure):
dpkg: dependency problems prevent configuration of netplan.io:
netplan.io depends on python3; however:
dpkg: error processing package netplan.io (--configure):
dpkg: dependency problems prevent configuration of command-not-found:
command-not-found depends on python3-commandnotfound (= 18.04.5); however:
Package python3-commandnotfound is not configured yet.
dpkg: error processing package command-not-found (--configure):
dpkg: dependency problems prevent configuration of ubuntu-release-upgrader-core:
ubuntu-release-upgrader-core depends on python3:any (>= 3.2~); however:
dpkg: error processing package ubuntu-release-upgrader-core (--configure):
dpkg: dependency problems prevent configuration of python3-apport:
python3-apport depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-apport (--configure):
dpkg: dependency problems prevent configuration of gnome-terminal:
gnome-terminal depends on python3; however:
dpkg: error processing package gnome-terminal (--configure):
dpkg: dependency problems prevent configuration of ubuntu-session:
ubuntu-session depends on gnome-shell (>= 3.24.3-0ubuntu2); however:
Package gnome-shell is not configured yet.
dpkg: error processing package ubuntu-session (--configure):
dpkg: dependency problems prevent configuration of python3-problem-report:
python3-problem-report depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-problem-report (--configure):
dpkg: dependency problems prevent configuration of software-properties-gtk:
software-properties-gtk depends on python3:any (>= 3.3.2-2~); however:
software-properties-gtk depends on python3; however:
dpkg: error processing package software-properties-gtk (--configure):
dpkg: dependency problems prevent configuration of nplan:
nplan depends on netplan.io; however:
Package netplan.io is not configured yet.
dpkg: error processing package nplan (--configure):
dpkg: dependency problems prevent configuration of update-notifier:
update-notifier depends on update-notifier-common (= 3.192.1.3); however:
Package update-notifier-common is not configured yet.
dpkg: error processing package update-notifier (--configure):
dpkg: dependency problems prevent configuration of gnome-software:
gnome-software depends on software-properties-gtk; however:
Package software-properties-gtk is not configured yet.
dpkg: error processing package gnome-software (--configure):
dpkg: dependency problems prevent configuration of unattended-upgrades:
unattended-upgrades depends on python3; however:
dpkg: error processing package unattended-upgrades (--configure):
dpkg: dependency problems prevent configuration of apport:
apport depends on python3; however:
apport depends on python3-apport (>= 2.20.9-0ubuntu7.2); however:
Package python3-apport is not configured yet.
dpkg: error processing package apport (--configure):
dpkg: dependency problems prevent configuration of update-manager:
update-manager depends on update-notifier; however:
Package update-notifier is not configured yet.
update-manager depends on policykit-1-gnome | polkit-kde-agent-1 | lxpolkit | lxqt-policykit | mate-polkit | polkit-1-auth-agent; however:
Package policykit-1-gnome is not installed.
Package polkit-kde-agent-1 is not installed.
Package lxpolkit is not installed.
Package lxqt-policykit is not installed.
Package mate-polkit is not installed.
Package polkit-1-auth-agent is not installed.
Package gnome-shell which provides polkit-1-auth-agent is not configured yet.
dpkg: error processing package update-manager (--configure):
dpkg: dependency problems prevent configuration of python3-software-properties:
python3-software-properties depends on python3:any (>= 3.3.2-2~); however:
python3-software-properties depends on python3; however:
dpkg: error processing package python3-software-properties (--configure):
dpkg: dependency problems prevent processing triggers for gnome-menus:
gnome-menus depends on python3:any (>= 3.1~); however:
dpkg: error processing package gnome-menus (--configure):
dependency problems - leaving triggers unprocessed
dpkg: dependency problems prevent configuration of language-selector-gnome:
language-selector-gnome depends on language-selector-common (= 0.188.1); however:
Package language-selector-common is not configured yet.
language-selector-gnome depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package language-selector-gnome (--configure):
dpkg: dependency problems prevent configuration of flashplugin-installer:
flashplugin-installer depends on update-notifier-common (>= 0.119ubuntu2); however:
dpkg: error processing package flashplugin-installer (--configure):
dpkg: dependency problems prevent configuration of python3-dbus.mainloop.pyqt5:
python3-dbus.mainloop.pyqt5 depends on python3 (<< 3.7); however:
python3-dbus.mainloop.pyqt5 depends on python3 (>= 3.6~); however:
python3-dbus.mainloop.pyqt5 depends on python3:any (>= 3.3~); however:No apport report written because MaxReports is reached already
dpkg: error processing package python3-dbus.mainloop.pyqt5 (--configure):
dpkg: dependency problems prevent configuration of python3-louis:
python3-louis depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-louis (--configure):
dpkg: dependency problems prevent configuration of networkd-dispatcher:
networkd-dispatcher depends on python3:any; however:
dpkg: error processing package networkd-dispatcher (--configure):
dpkg: dependency problems prevent configuration of python3-distupgrade:
python3-distupgrade depends on python3:any (>= 3.3.2-2~); however:
python3-distupgrade depends on python3-update-manager (>= 1:0.196.2~); however:
Package python3-update-manager is not configured yet.
dpkg: error processing package python3-distupgrade (--configure):
dpkg: dependency problems prevent configuration of software-properties-common:
software-properties-common depends on python3:any (>= 3.3.2-2~); however:
software-properties-common depends on python3; however:
software-properties-common depends on python3-software-properties (= 0.96.24.32.4); however:
Package python3-software-properties is not configured yet.
dpkg: error processing package software-properties-common (--configure):
dpkg: dependency problems prevent configuration of python3-cryptography:
python3-cryptography depends on python3 (>= 3~); however:
python3-cryptography depends on python3:any (>= 3.4~); however:
dpkg: error processing package python3-cryptography (--configure):
dpkg: dependency problems prevent configuration of nautilus-extension-gnome-terminal:
nautilus-extension-gnome-terminal depends on gnome-terminal (= 3.28.2-1ubuntu1~18.04.1); however:
Package gnome-terminal is not configured yet.
dpkg: error processing package nautilus-extension-gnome-terminal (--configure):
dpkg: dependency problems prevent configuration of python3-speechd:
python3-speechd depends on python3-xdg; however:
Package python3-xdg is not configured yet.
python3-speechd depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-speechd (--configure):
dpkg: dependency problems prevent processing triggers for ufw:
ufw depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package ufw (--configure):
dpkg: dependency problems prevent configuration of ubuntu-release-upgrader-gtk:
ubuntu-release-upgrader-gtk depends on ubuntu-release-upgrader-core (= 1:18.04.21); however:
Package ubuntu-release-upgrader-core is not configured yet.
ubuntu-release-upgrader-gtk depends on update-manager; however:
Package update-manager is not configured yet.
ubuntu-release-upgrader-gtk depends on python3-distupgrade (= 1:18.04.21); however:
Package python3-distupgrade is not configured yet.
dpkg: error processing package ubuntu-release-upgrader-gtk (--configure):
dpkg: dependency problems prevent configuration of update-manager-core:
update-manager-core depends on python3:any (>= 3.2~); however:
update-manager-core depends on python3-update-manager (= 1:18.04.11.4); however:
update-manager-core depends on ubuntu-release-upgrader-core (>= 1:18.04.9); however:
dpkg: error processing package update-manager-core (--configure):
dpkg: dependency problems prevent configuration of ubuntu-software:
ubuntu-software depends on gnome-software (>= 3.28.1-0ubuntu4.18.04.1); however:
Package gnome-software is not configured yet.
dpkg: error processing package ubuntu-software (--configure):
dpkg: dependency problems prevent configuration of python3-apt:
python3-apt depends on python3 (<< 3.7); however:
python3-apt depends on python3 (>= 3.6~); however:
python3-apt depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-apt (--configure):
dpkg: dependency problems prevent configuration of gnome-software-plugin-snap:
gnome-software-plugin-snap depends on gnome-software (= 3.28.1-0ubuntu4.18.04.1); however:
dpkg: error processing package gnome-software-plugin-snap (--configureNo apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of gdm3:
gdm3 depends on gnome-shell (>= 3.19.92); however:
dpkg: error processing package gdm3 (--configure):
dpkg: dependency problems prevent configuration of gnome-control-center:
gnome-control-center depends on language-selector-gnome (>= 0.179~); however:
Package language-selector-gnome is not configured yet.
dpkg: error processing package gnome-control-center (--configure):
python3
python3-pyqt5
python3-xdg
gnome-shell
apport-gtk
netplan.io
command-not-found
python3-apport
gnome-terminal
ubuntu-session
nplan
update-notifier
gnome-software
unattended-upgrades
apport
update-manager
gnome-menus
python3-louis
networkd-dispatcher
python3-distupgrade
python3-speechd
ufw
update-manager-core
ubuntu-software
python3-apt
gdm3
How can I debug/fix this?
