I am running Ubuntu 18.04 and some time ago I have installed the HPLIP software from the official web site because the one in the repository was not working properly. Afterwards I had no problem, until today. Now if I try to perform a regular upgrade I am getting the following error:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
9 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up python3 (3.6.5-3ubuntu1) ...
running python rtupdate hooks for python3.6...
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/__init__.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aboutdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/aligndialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/cleandialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/colorcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devicesetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/deviceuricombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr5_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/devmgr_ext.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabgrouptable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabnametable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/fabwindow_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/faxsetupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/filetable.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/firmwaredialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/infodialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/linefeedcaldialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/loadpapergroupbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/makecopiesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/mimetypesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/nodevicesdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindiagnose_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/plugindialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pluginlicensedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/pqdiagdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printernamecombobox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettings_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printsettingstoolbox.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/printtestpagedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/queuesconf.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/readonlyradiobutton.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/sendfaxdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/settingsdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/setupdialog_base5.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systemtray.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/systrayframe_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/ui_utils.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/upgradedialog_base.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog.py'
[Errno 2] No such file or directory: '/usr/share/hplip/ui5/wifisetupdialog_base.py'
error running python rtupdate hook hplip-data
dpkg: error processing package python3 (--configure):
installed python3 package post-installation script subprocess returned error exit status 4
dpkg: dependency problems prevent configuration of update-notifier-common:
update-notifier-common depends on python3:any; however:
Package python3 is not configured yet.
dpkg: error processing package update-notifier-common (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of python3-update-manager:
python3-update-manager depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-update-manager (--configure):
dpkg: dependency problems prevent configuration of gnome-shell:
gnome-shell depends on python3; however:
dpkg: error processing package gnome-shell (--configure):
dpkg: dependency problems prevent configuration of update-notifier:
update-notifier depends on update-notifier-common (= 3.192.1.3); however:
Package update-notifiNo apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
er-common is not configured yet.
dpkg: error processing package update-notifier (--configure):
dpkg: dependency problems prevent configuration of unattended-upgrades:
unattended-upgrades depends on python3; however:
dpkg: error processing package unattended-upgrades (--configure):
dpkg: dependency problems prevent configuration of update-manager:
update-manager depends on update-notifier; however:
Package update-notifier is not configured yet.
update-manager depends on policykit-1-gnome | polkit-kde-agent-1 | lxpolkit | lxqt-policykit | mate-polkit | polkit-1-auth-agent; however:
Package policykit-1-gnome is not installed.
Package polkit-kde-agent-1 is not installed.
Package lxpolkit is not installed.
Package lxqt-policykit is not installed.
Package mate-polkit is not installed.
Package polkit-1-auth-agent is not installed.
Package gnome-shell which provides polkit-1-auth-agent is not configured yet.
dpkg: error processing package update-manager (--configure):
dpkg: dependency problems prevent processing triggers for gnome-menus:
gnome-menus depends on python3:any (>= 3.1~); however:
dpkg: error processing package gnome-menus (--configure):
dependency problems - leaving triggers unprocessed
dpkg: dependency problems prevent processing triggers for ufw:
ufw depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package ufw (--configure):
dpkg: dependency problems prevent configuration of update-manager-core:
update-manager-core depends on python3:any (>= 3.2~); however:
update-manager-core depends on python3-update-manager (= 1:18.04.11.3); however:
Package python3-update-manager is not configured yet.
dpkg: error processing package update-manager-core (--configure):
dpkg: dependency problems prevent configuration of gdm3:
gdm3 depends on gnome-shell (>= 3.19.92); however:
Package gnome-shell is not configured yet.
dpkg: error processing package gdm3 (--configure):
python3
gnome-shell
update-notifier
unattended-upgrades
update-manager
gnome-menus
ufw
update-manager-core
gdm3
have you any suggestion on how to solve this?
