44
When I attempt to install mongodb using the instructions on https://docs.mongodb.com/getting-started/shell/tutorial/install-mongodb-on-ubuntu/ on 16.04 I get the following result on the install step:
jonathan@poseidon:~$ sudo apt-get install mongodb-org
Reading package lists... Done
Building dependency tree
Package mongodb-org is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'mongodb-org' has no installation candidate
I checked the HTTP traffic with Wireshark and found that the only traffic was a HTTP GET for the list and a HTTP 304 response which suggests that the problem lies in my local configuration files. My sources.list.d file contains the following entry:
mongodb-org-3.4.list
What do I need to do to continue to troubleshoot this problem?
EDIT: I tried to do this again on a new install of 16.04 under VirtualBox. I retrieved the key, created the list file, and did sudo apt update with the following results:
jonathan@Ubuntu-16:~$ sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 0C49F3730359A14518585931BC711F9BA15703C6
[sudo] password for jonathan:
Executing: /tmp/tmp.uWYpRUWfjK/gpg.1.sh --keyserver
--recv
gpg: requesting key A15703C6 from hkp server keyserver.ubuntu.com
gpg: key A15703C6: public key "MongoDB 3.4 Release Signing Key <packaging@mongodb.com>" imported
gpg: Total number processed: 1
gpg:               imported: 1  (RSA: 1)
jonathan@Ubuntu-16:~$ echo "deb http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-3.4.list
jonathan@Ubuntu-16:~$ sudo apt update
Ign:1 http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 InRelease
Get:2 http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 Release [3 462 B]
Hit:3 http://mx.archive.ubuntu.com/ubuntu xenial InRelease
Get:4 http://security.ubuntu.com/ubuntu xenial-security InRelease [94.5 kB]
Get:5 http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 Release.gpg [801 B]
Get:6 http://mx.archive.ubuntu.com/ubuntu xenial-updates InRelease [95.7 kB]
Ign:5 http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 Release.gpg
Get:7 http://mx.archive.ubuntu.com/ubuntu xenial-backports InRelease [92.2 kB]
W: GPG error: http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D68FA50FEA312927
E: The repository 'http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 Release' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
As you can see, the key retrieved was for Mongodb 3.4, not Mongodb 3.2 and this explains the GPG failure in apt update. Any one know where to get the correct key?
Jonathan
  • 1,498
7 Answers7
120
Ubuntu 18.04 and MongoDB 4.2
First, remove MongoDB from previous if installed:
sudo apt remove --autoremove mongodb-org
Remove any mongodb repo list files:
sudo rm /etc/apt/sources.list.d/mongodb*.list
sudo apt update
Now, add the new key:
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 4B7C549A058F8B6B
Add the new repository:
echo "deb [arch=amd64] http://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/4.2 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-4.2.list
Install MongoDB
sudo apt update
sudo apt install mongodb-org
Enable and start the mongod server service:
systemctl enable mongod.service
systemctl start mongod.service
Check your installation:
~$ mongo --version
MongoDB shell version v4.2.2
git version: a0bbbff6ada159e19298d37946ac8dc4b497eadf
OpenSSL version: OpenSSL 1.1.1  11 Sep 2018
allocator: tcmalloc
modules: none
build environment:
    distmod: ubuntu1804
    distarch: x86_64
    target_arch: x86_64
You can also check your service has started:
~$ systemctl status mongod.service
● mongod.service - MongoDB Database Server
   Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset: e
   Active: active (running) since Mon 2019-12-30 08:05:48 MST; 1min 7s ago
     Docs: https://docs.mongodb.org/manual
 Main PID: 7941 (mongod)
   CGroup: /system.slice/mongod.service
           └─7941 /usr/bin/mongod --config /etc/mongod.conf
Ubuntu 20.04 and MongoDB 4.4 or MongoDB 5.0
systemctl stop mongod.service
systemctl disable mongod.service
sudo apt update
Now, add the new key for MongoDB 4.4:
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 656408E390CFB1F5
The new key for MongoDB 5.0:
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv B00A0BD1E2C63C11
Add the new repository for MongoDB 4.4:
echo "deb [arch=amd64] http://repo.mongodb.org/apt/ubuntu $(lsb_release -sc)/mongodb-org/4.4 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org.list
Or the new repository for MongoDB 5.0:
echo "deb [arch=amd64] http://repo.mongodb.org/apt/ubuntu $(lsb_release -sc)/mongodb-org/5.0 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org.list
Install MongoDB
sudo apt update
~$ mongo --version
MongoDB shell version v4.4.3
Build Info: {
    "version": "4.4.3",
    "gitVersion": "913d6b62acfbb344dde1b116f4161360acd8fd13",
    "openSSLVersion": "OpenSSL 1.1.1f  31 Mar 2020",
    "modules": [],
    "allocator": "tcmalloc",
    "environment": {
        "distmod": "ubuntu2004",
        "distarch": "x86_64",
        "target_arch": "x86_64"
Or
$ mongo --version
MongoDB shell version v5.0.2
Build Info: {
    "version": "5.0.2",
    "gitVersion": "6d9ec525e78465dcecadcff99cce953d380fedc8",
    "modules": [],
    "environment": {
     Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset>
     Active: active (running) since Sun 2021-01-24 07:52:50 MST; 27s ago
   Main PID: 2353629 (mongod)
     Memory: 59.2M
             └─2353629 /usr/bin/mongod --config /etc/mongod.conf
Jan 24 07:52:50 terrance-ubuntu systemd[1]: Started MongoDB Database Server.
Ubuntu 22.04 and MongoDB 6.0
The MongoDB repos are not 100% ready for 22.04 yet, so you will have to use the Focal repository from them to install it. Also, the repo doesn't have the key ready for GPG since apt-key is now deprecated, but these instructions still work for now.
sudo apt update
You might need to install gpg before doing the next step.
sudo apt install gpg
Now, add the new key for MongoDB 6.0:
curl -fsSL https://pgp.mongodb.com/server-6.0.asc | sudo gpg --dearmor -o /usr/share/keyrings/mongodb60.gpg
Add the new repository for MongoDB 6.0 (You have to use the Focal repo as the Jammy repo does not contain the mongodb-org install for the mongod server):
echo "deb [arch=amd64 signed-by=/usr/share/keyrings/mongodb60.gpg] http://repo.mongodb.org/apt/ubuntu focal/mongodb-org/6.0 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org.list
Install MongoDB
sudo apt update
mongod --version
db version v6.0.2
Build Info: {
    "version": "6.0.2",
    "gitVersion": "94fb7dfc8b974f1f5343e7ea394d0d9deedba50e",
    "modules": [],
    "environment": {
systemctl status mongod.service ● mongod.service - MongoDB Database Server Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset> Active: active (running) since Thu 2022-10-13 08:13:21 MDT; 39s ago Docs: https://docs.mongodb.org/manual Main PID: 44048 (mongod) Memory: 68.1M CPU: 1.169s CGroup: /system.slice/mongod.service └─44048 /usr/bin/mongod --config /etc/mongod.conf
Oct 13 08:13:21 terrance-ubuntu systemd[1]: Started MongoDB Database Server.
Hope this helps!
Terrance
  • 43,712
16
In addition to @Terrance 's answer, here is how you can find appropriate sig key. Example is applicable to mongodb in this case but can be used for any other package similarly. Before you execute lines from @Terrance 's answer:
  1. Go to ubuntu key server to find actual key
  2. Search for string of interest (mongodb in case) and submit that first form (you don't need second form for this) - click Search! button
  1. On provided search list seek for your version (it was 3.4 in my case here in example)
  1. You can see two rows with keys there. Focus on most actual by date. First string is date created while second one is date valid due.
  2. Use sig from row mentioned in point 5 - in case from picture it would be A15703C6
  3. Continue with Terrance 's answer wether you need to install package or upgrade like myself
Tpojka
  • 261
First run:
$ sudo rm /etc/apt/sources.list.d/mongodb*.list
It would be recommended to also remove any lines that are related to MongoDB from the /etc/apt/sources.list file.
Then do a fresh installation of MongoDB using the commands provided in the official MongoDB intstallation instructions for Ubuntu.
Commands in provided link are given below
wget -qO - https://www.mongodb.org/static/pgp/server-4.2.asc | sudo apt-key add -
sudo apt-get install gnupg
echo "deb [ arch=amd64 ] https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/4.2 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-4.2.list
sudo apt-get update
sudo apt-get install -y mongodb-org
sudo service mongod start
sudo service mongod status
Terrance
  • 43,712
Lakshmi
  • 121
Nothing worked for me either, so I went to the mogodb website and followed these instructions to install from tarball:
Install dependencies:
sudo apt-get install libcurl3 openssl
Download the tarball from this page
cd to the Downloads directory or wherever the file went, and extract it:
tar -zxvf mongodb-linux-*-4.0.1.tgz
The binaries are in the bin directory of the extracted structure. You can add this directory to PATH or copy the files to /usr/local/bin or another PATH location.
Zanna
  • 72,312
I was struggling today to install mongodb 4.2 in Ubuntu 20.04.1 LTS (Focal Fossa). I am a new user and its took me time to figure it out. Answer written by @Terrance helped me to solve my problem. I followed the below steps to install it in my system:
sudo apt update
sudo apt update
Hope this will help others. Thank you.
BC Smith
  • 101
Hopefully, this can be helpful for installing MongoDB version 3.4.17
(this worked for me in ubuntu focal 20.04.01 LTS but hopefully it would work on other versions as well!)
Try this:
echo "deb http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.4 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-3.4.list
sudo apt update
apt-cache policy libssl1.0-dev
sudo apt-get install libssl1.0-dev
sudo apt-get install -y mongodb-org=3.4.17 mongodb-org-server=3.4.17 mongodb-org-shell=3.4.17 mongodb-org-mongos=3.4.17 mongodb-org-tools=3.4.17
You can run one of the following commands depending on your preference of using either wget or curl, after making sure for the version that you should use (here 3.2):
  • Command with wget:
    wget -qO - https://www.mongodb.org/static/pgp/server-3.2.asc | sudo apt-key add -
  • Command with curl:
    curl -sLO https://www.mongodb.org/static/pgp/server-3.2.asc && sudo /usr/bin/apt-key add server-3.2.asc
