tried installing mongodb-org several times in my ubuntu 22.04 and followed many youtube videos as well as document tutorials but failed to install it.
{"t":{"$date":"2022-10-14T23:57:58.874+05:30"},"s":"I", "c":"CONTROL", "id":23285, "ctx":"-","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"} {"t":{"$date":"2022-10-14T23:57:58.879+05:30"},"s":"I", "c":"NETWORK", "id":4915701, "ctx":"main","msg":"Initialized wire specification","attr":{"spec":{"incomingExternalClient":{"minWireVersion":0,"maxWireVersion":13},"incomingInternalClient":{"minWireVersion":0,"maxWireVersion":13},"outgoing":{"minWireVersion":0,"maxWireVersion":13},"isInternalClient":true}}} {"t":{"$date":"2022-10-14T23:57:58.879+05:30"},"s":"W", "c":"ASIO", "id":22601, "ctx":"main","msg":"No TransportLayer configured during NetworkInterface startup"} {"t":{"$date":"2022-10-14T23:57:58.879+05:30"},"s":"I", "c":"NETWORK", "id":4648601, "ctx":"main","msg":"Implicit TCP FastOpen unavailable. If TCP FastOpen is required, set tcpFastOpenServer, tcpFastOpenClient, and tcpFastOpenQueueSize."} {"t":{"$date":"2022-10-14T23:57:58.882+05:30"},"s":"W", "c":"ASIO", "id":22601, "ctx":"main","msg":"No TransportLayer configured during NetworkInterface startup"} {"t":{"$date":"2022-10-14T23:57:58.882+05:30"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationDonorService","ns":"config.tenantMigrationDonors"}} {"t":{"$date":"2022-10-14T23:57:58.882+05:30"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationRecipientService","ns":"config.tenantMigrationRecipients"}} {"t":{"$date":"2022-10-14T23:57:58.882+05:30"},"s":"I", "c":"CONTROL", "id":5945603, "ctx":"main","msg":"Multi threading initialized"} {"t":{"$date":"2022-10-14T23:57:58.883+05:30"},"s":"I", "c":"CONTROL", "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":6365,"port":27017,"dbPath":"/data/db","architecture":"64-bit","host":"naeemgg"}}
running mongod showing the above and checking status shows
`mongod.service - MongoDB Database Server Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Fri 2022-10-14 23:13:54 IST; 53min ago Docs: https://docs.mongodb.org/manual Process: 2037 ExecStart=/usr/bin/mongod --config /etc/mongod.conf (code=exited, status=14) Main PID: 2037 (code=exited, status=14) CPU: 964ms
Oct 14 23:13:53 johns systemd[1]: Started MongoDB Database Server. Oct 14 23:13:54 johns systemd[1]: mongod.service: Main process exited, code=exited, status=1> Oct 14 23:13:54 johns systemd[1]: mongod.service: Failed with result 'exit-code'.`
Running mongo shows :
MongoDB shell version v5.0.13 connecting to: mongodb://127.0.0.1:27017/?compressors=disabled&gssapiServiceName=mongodb Error: couldn't connect to server 127.0.0.1:27017, connection attempt failed: SocketException: Error connecting to 127.0.0.1:27017 :: caused by :: Connection refused : connect@src/mongo/shell/mongo.js:372:17 @(connect):2:6 exception: connect failed exiting with code 1
