Others have asked this question, but I have found no answer that works for me. I am trying to install MongoDB on Ubuntu 20.04. I have been following the guide at https://docs.mongodb.com/manual/tutorial/install-mongodb-on-ubuntu/, but run into trouble during installation. An error occurs during install (first error below), then I verify the install worked with --version command, it seems installed, I try to run, and get the subsequent failure (mongod.service not found).
 /tmp/apt-dpkg-install-kD4T9j/0-mongodb-database-tools_100.5.0_amd64.deb
 /tmp/apt-dpkg-install-kD4T9j/3-mongodb-org-server_5.0.2_amd64.deb
 /tmp/apt-dpkg-install-kD4T9j/4-mongodb-org-mongos_5.0.2_amd64.deb
jared@Pandora:~$ mongo --version
MongoDB shell version v5.0.2
Build Info: {
    "version": "5.0.2",
    "gitVersion": "6d9ec525e78465dcecadcff99cce953d380fedc8",
    "openSSLVersion": "OpenSSL 1.1.1f  31 Mar 2020",
    "modules": [],
    "allocator": "tcmalloc",
    "environment": {
        "distmod": "ubuntu2004",
        "distarch": "x86_64",
        "target_arch": "x86_64"
jared@Pandora:~$ sudo systemctl start mongod
Failed to start mongod.service: Unit mongod.service not found.
jared@Pandora:~$ sudo systemctl daemon-reload
Then I tried again double checking to remove previous files as per Cool Kev's advice below. Here is the complete new install and error printout:
jared@Pandora:~$ sudo apt install mongodb-org
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  mongodb-database-tools mongodb-mongosh mongodb-org-database
  mongodb-org-database-tools-extra mongodb-org-mongos mongodb-org-server
  mongodb-org-shell mongodb-org-tools
The following NEW packages will be installed:
  mongodb-database-tools mongodb-mongosh mongodb-org mongodb-org-database
0 upgraded, 9 newly installed, 0 to remove and 23 not upgraded.
Need to get 0 B/147 MB of archives.
After this operation, 449 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 197683 files and directories currently installed.)
Preparing to unpack .../0-mongodb-database-tools_100.5.0_amd64.deb ...
Unpacking mongodb-database-tools (100.5.0) ...
Selecting previously unselected package mongodb-mongosh.
Preparing to unpack .../1-mongodb-mongosh_1.0.6_amd64.deb ...
Unpacking mongodb-mongosh (1.0.6) ...
Selecting previously unselected package mongodb-org-shell.
Preparing to unpack .../2-mongodb-org-shell_5.0.2_amd64.deb ...
Unpacking mongodb-org-shell (5.0.2) ...
Preparing to unpack .../3-mongodb-org-server_5.0.2_amd64.deb ...
Unpacking mongodb-org-server (5.0.2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-h1NnWS/3-mongodb-org-server
_5.0.2_amd64.deb (--unpack):
 trying to overwrite '/usr/bin/mongod', which is also in package mongodb-server-
core 1:3.6.9+really3.6.8+90~g8e540c0b6d-0ubuntu5.2
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Preparing to unpack .../4-mongodb-org-mongos_5.0.2_amd64.deb ...
Unpacking mongodb-org-mongos (5.0.2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-h1NnWS/4-mongodb-org-mongos
 trying to overwrite '/usr/bin/mongos', which is also in package mongodb-server-
Selecting previously unselected package mongodb-org-database-tools-extra.
Preparing to unpack .../5-mongodb-org-database-tools-extra_5.0.2_amd64.deb ...
Unpacking mongodb-org-database-tools-extra (5.0.2) ...
Selecting previously unselected package mongodb-org-database.
Preparing to unpack .../6-mongodb-org-database_5.0.2_amd64.deb ...
Unpacking mongodb-org-database (5.0.2) ...
Selecting previously unselected package mongodb-org-tools.
Preparing to unpack .../7-mongodb-org-tools_5.0.2_amd64.deb ...
Unpacking mongodb-org-tools (5.0.2) ...
Selecting previously unselected package mongodb-org.
Preparing to unpack .../8-mongodb-org_5.0.2_amd64.deb ...
Unpacking mongodb-org (5.0.2) ...
 /tmp/apt-dpkg-install-h1NnWS/3-mongodb-org-server_5.0.2_amd64.deb
 /tmp/apt-dpkg-install-h1NnWS/4-mongodb-org-mongos_5.0.2_amd64.deb
Build Info: {
    "version": "5.0.2",
    "modules": [],
    "environment": {
jared@Pandora:~$ mongod
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] MongoDB starting : pid=25491 port=27017 dbpath=/data/db 64-bit host=Pandora
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] db version v3.6.8
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] git version: 8e540c0b6db93ce994cc548f000900bdc740f80a
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] OpenSSL version: OpenSSL 1.1.1f  31 Mar 2020
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] allocator: tcmalloc
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] modules: none
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] build environment:
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten]     distarch: x86_64
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten]     target_arch: x86_64
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] options: {}
2021-09-15T21:55:30.223-0400 I STORAGE  [initandlisten] exception in initAndListen: NonExistentPath: Data directory /data/db not found., terminating
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] now exiting
2021-09-15T21:55:30.223-0400 I CONTROL  [initandlisten] shutting down with code:100
connecting to: mongodb://127.0.0.1:27017/?compressors=disabled&gssapiServiceName=mongodb
Error: couldn't connect to server 127.0.0.1:27017, connection attempt failed: SocketException: Error connecting to 127.0.0.1:27017 :: caused by :: Connection refused :
connect@src/mongo/shell/mongo.js:372:17
@(connect):2:6
exception: connect failed
exiting with code 1
jared@Pandora:~$
Just to confirm, you didn't already have the MongoDB package provided by Ubuntu installed before installing the package from the mongodb.org repository that you added during installation correctly? It might go without saying but there are pkg conflicts. If you're unsure if there were preexisting versions, you could always:
sudo apt remove mongodb-org*
sudo apt autoremove
Assuming no snags there, reattempt install of the mongo.org version
karel
  • 122,292
  • 133
  • 301
  • 332
Solved! Seems like:
sudo apt-get purge mongodb-*
was able to actually rid my system of all old mongo files, allowing me a clean install. Thanks for all who helped!
