This message show in terminal....
You might want to run 'apt --fix-broken install' to correct these.
mongodb-org-database : Depends: mongodb-org-server but it is not going to be installed
Depends: mongodb-org-mongos but it is not going to be installed
mongodb-org-tools : Depends: mongodb-database-tools but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
After enter this:
~$ apt --fix-broken install
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
