I have Ubuntu 16.04 machine with MongoDB 2.6.10 install.
Now I want to upgrade MongoDB to latest version, i.e., 3.4
What is the best way to Upgrade?
You can do as following
$ sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 0C49F3730359A14518585931BC711F9BA15703C6
$ echo "deb http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.4 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-3.4.list
$ sudo apt-get update
$ sudo apt-get install -y mongodb-org
after upgrading your service will be masked. To unmask it
sudo systemctl unmask mongodb
for more detail see:
update:
If you use different ubuntu version, you should update <UBUNTU VERSION> in this command:
$ echo "deb http://repo.mongodb.org/apt/ubuntu <UBUNTU VERSION>/mongodb-org/3.4 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-3.4.list
For example, if you use 18.10, change it to cosmic You can find your version with this command
$ lsb_release -a
