I'm downloading mongoDB on Linux Ubuntu Version 22.04.1 LTS, facing download error
I tried 3 solution from stack overflow discussion https://stackoverflow.com/questions/51417708/unable-to-install-mongodb-properly-on-ubuntu-18-04-lts, but still not work , keep facing
here are the 3 ways I tried:
(base) joy@joy-System-Product-Name:~$ sudo apt-get install -y mongodb-org
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: mongodb-org-mongos : Depends: libssl1.1 (>= 1.1.1) but it is not installable mongodb-org-server : Depends: libssl1.1 (>= 1.1.1) but it is not installable E: Unable to correct problems, you have held broken packages.
I'm not sure what solution can perfectly solve my problem, that I need a hand here
more detail form beginning:
- 1.) I uninstall MongoDB, make sure no file or any stuff left
https://www.mongodb.com/basics/uninstall-mongodb
sudo service mongod stop
sudo apt-get purge mongodb-org*
sudo rm -r/var/log/mongodb /var/lib/mongodb
service mongod status
result:
(base) joy@joy-System-Product-Name:~$ sudo rm -r /var/log/mongodb /var/lib/mongodb
rm: cannot remove '/var/log/mongodb': No such file or directory
rm: cannot remove '/var/lib/mongodb': No such file or directory
(base) joy@joy-System-Product-Name:~$ service mongod status
Unit mongod.service could not be found.
- 2.) I tried the solution from discussion, first solution not work, still facing E: Package 'mongodb' has no installation candidate
(pic)I followed first solution -> failed
(base) joy@joy-System-Product-Name:~$ sudo apt-get purge mongodb-org*
... I skip a lot(Done) here ...
0 upgraded, 0 newly installed, 0 to remove and 96 not upgraded.
(base) joy@joy-System-Product-Name:~$ sudo apt-get install mongodb Reading package lists... Done Building dependency tree... Done Reading state information... Done Package mongodb is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source
- 3.) Tried second solution not work, still facing E: Unable to correct problems, you have held broken packages.
tired second way to install link- Install MongoDB Community Edition on Ubuntu https://www.mongodb.com/docs/manual/tutorial/install-mongodb-on-ubuntu/
wget -qO - https://www.mongodb.org/static/pgp/server-6.0.asc | sudo apt-key add -
echo "deb [ arch=amd64,arm64 ] https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/6.0 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-6.0.list
sudo apt-get update
The second way last step I face
E: Unable to correct problems, you have held broken packages. I checked, I did't keep any file left
I list up all the file for what I have in linux cmd:
(pic) . list , ls for all the files
so is that I'm either facing
or
E: Unable to correct problems, you have held broken packages.(I assum I checked and deleted mongo file before run this)
when I tried about 10 solutions from discussions
tried use jammy instead of focal in
(pic)result 01
(pic)result 02 still facing:
j ton
  • 131
