206
While installing Android Studio on Ubuntu 14.04 I get the message that my Java version (javac 1.7.0_79) is causing problems. I found a solution of how to install a newer Oracle version of Java:
sudo apt-add-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java8-installer
However I'm afraid that this might overwrite my existing open-jdk version of Java. Since I don't know which of my programs depend on Java, I fear that this could crash these other programs.
Is there a way to make sure apt-get doesn't overwrite my previous Java? I would basically like to have installed both and be able to switch between them manually, depending on what version I need.
fosslinux
  • 3,881
mcExchange
  • 3,398
7 Answers7
248
Apt-get won't overwrite the existing java versions.
To switch between installed java versions, use the update-java-alternatives command.
List all java versions:
update-java-alternatives --list
Set java version as default (needs root permissions):
sudo update-java-alternatives --set /path/to/java/version
...where /path/to/java/version is one of those listed by the previous command (e.g. /usr/lib/jvm/java-7-openjdk-amd64).
Additional information:
update-java-alternatives is a convenience tool that uses Debian's alternatives system (update-alternatives) to set a bunch of links to the specified java version (e.g. java, javac, ...).
danzel
  • 6,533
166
Use
sudo update-alternatives --config java
which lists all installed versions with current active one marked and provides dialog to switch:
There are 3 choices for the alternative java (providing /usr/bin/java).
Selection    Path...
  0            /usr/lib/jvm/java-9-oracle/bin/java...
* 1            /usr/lib/jvm/java-7-oracle/jre/bin/java...
  2            /usr/lib/jvm/java-8-oracle/jre/bin/java...
  3            /usr/lib/jvm/java-9-oracle/bin/java...
Press <enter> to keep...[*], or type selection number:
Use
export JAVA_HOME="$(jrunscript -e 'java.lang.System.out.println(java.lang.System.getProperty("java.home"));')"
to set $JAVA_HOME from current active version
muet
  • 1,661
21
Configuring Java
You can configure which version is the default for use in the command line by using update-alternatives, which manages which symbolic links are used for different commands.
The output will look something like the following.
There are 5 choices for the alternative java (providing /usr/bin/java).
  Selection    Path                                            Priority   Status
* 0            /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java   1081      auto mode
  1            /usr/lib/jvm/java-6-oracle/jre/bin/java          1         manual mode
  2            /usr/lib/jvm/java-7-oracle/jre/bin/java          2         manual mode
  3            /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java   1081      manual mode
  4            /usr/lib/jvm/java-8-oracle/jre/bin/java          3         manual mode
  5            /usr/lib/jvm/java-9-oracle/bin/java              4         manual mode
Press <enter> to keep the current choice[*], or type selection number:
You can now choose the number to use as a default. This can also be done for other Java commands, such as the compiler (javac), the documentation generator (javadoc), the JAR signing tool (jarsigner), and more. You can use the following command, filling in the command you want to customize.
sudo update-alternatives --config command
Setting the JAVA_HOME Environment Variable
Many programs, such as Java servers, use the JAVA_HOME environment variable to determine the Java installation location.
Copy the path from your preferred installation and then open /etc/environment using Sublime Text or your favourite text editor.
sudo subl /etc/environment
At the end of this file, add the following line, making sure to replace the highlighted path with your own copied path.
JAVA_HOME="/usr/lib/jvm/java-8-oracle"
Save and exit the file, and reload it: source /etc/environment.
You can now test whether the environment variable has been set by executing the following command: echo $JAVA_HOME. This will return the path you just set.
12
Based on the answer from @muet, I found this to work seamlessly:
Add this to ~/.bashrc:
Add to aliases:
alias useJava8='yes | sudo apt-get install oracle-java8-set-default && source ~/.bashrc'
alias useJava7='yes | sudo apt-get install oracle-java7-set-default && source ~/.bashrc'
Then you can switch within the same shell using only: useJava7or useJava8
Zanna
  • 72,312
brianjohnsen
  • 121
Consider also using the GUI tool galternatives available through the ubuntu package manager.
mapto
  • 339
jrunscriptmay not be available in future releases, so safe choice is using export JAVA_HOME=$(dirname $(dirname $(readlink -f $(which java)))) as suggested by @ThiamTeck. Also .bashrc needs to be executed every time you change your java version using update-alternative command.
I have this in my .zshrc:
### Java
set_java_home() {
    export JAVA_HOME="$1"
    # Remove any existing java paths
    PATH=$(echo "$PATH" | sed -E -e 's|:/home/linuxbrew/.linuxbrew/opt/openjdk[^:]*/bin||g' -e 's|/home/linuxbrew/.linuxbrew/opt/openjdk[^:]*/bin:||g' -e 's|:/usr/local/jdk[^:]*/bin||g' -e 's|/usr/local/jdk[^:]*/bin:||g')
    # Add the new java path
    export PATH="$JAVA_HOME/bin:$PATH"
# Aliases to switch Java versions
alias java8='set_java_home $(brew --prefix openjdk@8)'
alias java11='set_java_home $(brew --prefix openjdk@11)'
alias java17='set_java_home $(brew --prefix openjdk@17)'
alias java21='set_java_home $(brew --prefix openjdk@21)'
# Set default Java version
java21
Note: I used brew to install all LTS versions (brew install openjdk@{version})
s3c
  • 111
