I am using ubuntu 16.04 LTS.
...$ java -version
java version "1.8.0_161"
Java(TM) SE Runtime Environment (build 1.8.0_161-b12)
Java HotSpot(TM) 64-Bit Server VM (build 25.161-b12, mixed mode)
...$ echo $JAVA_HOME
/usr/lib/jvm/java-8-oracle
I have tried to use multiple versions of java using the answer mentioned is this post.
...$ which java
/usr/bin/java
Downloaded jdk 1.8.0_151 from this link:
http://www.oracle.com/technetwork/java/archive-139210.html
Extracted it in home/b/ then tried the following command as mentioned in the post.
...$ export  PATH=/home/b/jdk1.8.0_151/bin:$PATH
... $ which java
/usr/bin/java
I am still getting the same java.
I have also tried:
...$ sudo update-alternatives --config java
here is 1 choice for the alternative java (providing /usr/bin/java).
Selection    Path                                     Priority   Status
  0            /usr/lib/jvm/java-8-oracle/jre/bin/java   1081      auto mode
* 1            /usr/lib/jvm/java-8-oracle/jre/bin/java   1081      manual mode
This is my $PATH:
...$ echo $PATH
/home/b/jdk1.8.0_151/bin:/home/junaid/anaconda2/bin:/usr/local/sbin:/usr/local/bin:
/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:
/usr/lib/jvm/java-8-oracle/bin:/usr/lib/jvm/java-8-oracle/db/bin:/usr/lib/jvm/java-8-oracle/jre/bin
Should I remove Java and download again? If yes, then how?
Chai T. Rex
  • 5,323
el323
  • 143
I had an issue as follows:
>Checking build tools versions...
>You asked for an OpenJDK based build but your version is
>java version "1.8.0_161" Java(TM) SE Runtime Environment (build 1.8.0_161-b12) Java HotSpot(TM) 64-Bit Server VM (build 25.161-b12, mixed mode).
>build/core/main.mk:175: error: stop.
>09:36:38 ckati failed with: exit status 1
>build/core/main.mk:21: recipe for target 'run_soong_ui' failed
>make: *** [run_soong_ui] Error 1
>#### make failed to build some targets (01:40 (mm:ss)) ####
The issue is solved for me by removing Oracle path from $EXPORT.
