My system is ubuntu 16.04. First I had uninstalled java10 and then tried installing java8 so I am getting the below mentioned error. Please anyone can help me regarding this error with detailed steps.Please help soon its urgent.
Unrecognized option: --version Error: Could not create the Java Virtual Machine. Error: A fatal exception has occurred. Program will exit
Make sure you are really typing:
java --version
If so, try with a single dash like:
java -version
double-beep
  • 195
  • 13
pete
  • 171
  1. Remove /usr/lib/jvm , this will remove jdk from your system
  2. Now again install using sudo apt install default-jdk
  3. Check command java-version, and it shows current installed version.
This worked for me!
andrew.46
  • 39,359
