Does anybody know the meaning of this error message?
java.lang.RuntimeException: failed to load system cursor: DnD.Cursor.CopyDrop
After new Install of Ubuntu 17.10 (Xfce), OpenJava1.8., Netbeans freezes while showing the splash. Another JavaApp, "TV-Browser", has problems too. Other Java Apps run properly. ~/.netbeans/8.2/var/log/messages.log shows:
Log Session: Wednesday, November 29, 2017 3:02:48 PM CET
System Info:
Product Version = NetBeans IDE 8.2 (Build 201609300101) (#5fd841261bf9)
Operating System = Linux version 4.13.0-17-generic running on amd64
Java; VM; Vendor = 1.8.0_151; OpenJDK 64-Bit Server VM 25.151-b12; Oracle Corporation
Runtime = OpenJDK Runtime Environment 1.8.0_151-8u151-b12-0ubuntu0.17.10.2-b12
Java Home = /usr/lib/jvm/java-8-openjdk-amd64/jre
System Locale; Encoding = de_DE (nb); UTF-8
Home Directory = /home/ralph
Current Directory = /home/ralph
User Directory = /home/ralph/.netbeans/8.2
Cache Directory = /home/ralph/.cache/netbeans/8.2
Installation = /usr/local/netbeans-8.2/nb
/usr/local/netbeans-8.2/ide
/usr/local/netbeans-8.2/extide
/usr/local/netbeans-8.2/java
/usr/local/netbeans-8.2/apisupport
/usr/local/netbeans-8.2/websvccommon
/usr/local/netbeans-8.2/profiler
/usr/local/netbeans-8.2/harness
/usr/local/netbeans-8.2/javafx
/usr/local/netbeans-8.2/platform
java.lang.RuntimeException: failed to load system cursor: DnD.Cursor.CopyDrop : cannot load system cursor: CopyDrop.32x32
at java.awt.dnd.DragSource.load(DragSource.java:135)
at java.awt.dnd.DragSource.<clinit>(DragSource.java:148)
Caused: java.lang.ExceptionInInitializerError
at org.netbeans.core.windows.view.ui.toolbars.DnDSupport.<clinit>(DnDSupport.java:118)
at org.netbeans.core.windows.view.ui.toolbars.ToolbarConfiguration.dndSupport(ToolbarConfiguration.java:132)
at org.netbeans.core.windows.view.ui.toolbars.ToolbarConfiguration.refresh(ToolbarConfiguration.java:312)
at org.netbeans.core.windows.view.ui.toolbars.ToolbarConfiguration.activate(ToolbarConfiguration.java:400)
at org.openide.awt.ToolbarPool.activate(ToolbarPool.java:245)
at org.openide.awt.ToolbarPool.setConfigurationNow(ToolbarPool.java:329)
at org.openide.awt.ToolbarPool.setConfiguration(ToolbarPool.java:301)
at org.netbeans.core.windows.view.DefaultView.showWindowSystem(DefaultView.java:567)
at org.netbeans.core.windows.view.DefaultView.windowSystemVisibilityChanged(DefaultView.java:542)
at org.netbeans.core.windows.view.DefaultView.changeGUI(DefaultView.java:187)
at org.netbeans.core.windows.ViewRequestor.dispatchRequest(ViewRequestor.java:275)
at org.netbeans.core.windows.ViewRequestor.processVisibilityRequest(ViewRequestor.java:264)
at org.netbeans.core.windows.ViewRequestor.postVisibilityRequest(ViewRequestor.java:201)
at org.netbeans.core.windows.ViewRequestor.scheduleRequest(ViewRequestor.java:121)
at org.netbeans.core.windows.Central.setVisible(Central.java:140)
at org.netbeans.core.windows.WindowManagerImpl.setVisible(WindowManagerImpl.java:931)
at org.netbeans.core.windows.WindowSystemImpl.show(WindowSystemImpl.java:105)
at org.netbeans.core.GuiRunLevel$InitWinSys.run(GuiRunLevel.java:244)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at org.netbeans.core.TimableEventQueue.dispatchEvent(TimableEventQueue.java:159)
[catch] at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
java.lang.RuntimeException: cannot load system cursor: CopyDrop.32x32
at sun.awt.X11.XToolkit.lazilyLoadDesktopProperty(XToolkit.java:1541)
at java.awt.Toolkit.getDesktopProperty(Toolkit.java:1803)
at java.awt.dnd.DragSource.load(DragSource.java:131)
Caused by: java.awt.AWTException: Exception: class java.lang.IllegalArgumentException Width (0) and height (0) must be non-zero occurred while creating cursor CopyDrop.32x32
at java.awt.Cursor.getSystemCustomCursor(Cursor.java:363)
at sun.awt.X11.XToolkit.lazilyLoadDesktopProperty(XToolkit.java:1539)
... 36 more
INFO [org.netbeans.modules.autoupdate.updateprovider.AutoupdateCatalogParser]: Unpaired license 00000008 without any module.
Zanna
  • 72,312
As noted by David Foerster in this comment, it appears that this bug in OpenJDK 8 has been squashed and the fix is to install OpenJDK 9. which is available for 17.10 in the Universe repository.
First, enable the repository if it isn't already.
Second install OpenJDK 9 with the command sudo apt install openjdk-9-jdk
If for some reason you wish to retain OpenJDK 8 you might want to familiarize yourself with how to switch between multiple java versions
Elder Geek
  • 36,752
