the linux uprising ppa is currently forcing version 11 of java on us.
sudo add-apt-repository ppa:linuxuprising/java
that's nice I like modern and being up to speed, but I have an app that'll only run with java 10.
webUpD8 stopped after 9 and linux uprising started at 10 and that worked (apparently..., I personally never got to test it) until they released 11 and now when you type :
sudo apt install oracle-java10-installer
you get :
Reading package lists... Done
Building dependency tree
Package oracle-java10-installer is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'oracle-java10-installer' has no installation candidate
only typing :
sudo apt install oracle-java11-installer
will work. that's the package that's being referenced above.
clearly something was done that was a little sloppy :
what are my options?
tatsu
  • 3,346
EDIT: If you have successfully installed openjdk-10-jdk package, than You just need to switch default jdk version using 'update-java-alternatives' command (as described here).
You could manually install openjdk (instead of using apt).
For example, openjdk 10 is available to download at jdk.java.net or adoptopenjdk.net.
Installation instructions are available at docs.oracle.com.
caspinos
  • 231
