Only when I'm closer to the router, it shows any signal, but when I'm just little far from it, it is not showing wifi routers signals.
Asked
Active
Viewed 2.7k times
10
With Ubuntu 16.04 and later, go to Parameter settings as nothing needs to be downloaded
Progress from Larry Finger from here
If you installed rtlwifi-new-dkms from Pilot6's PPA, it will need to be removed with
sudo apt-get remove rtlwifi-new-dkms
Reboot, then
sudo apt-get install git build-essential
git clone https://github.com/lwfinger/rtlwifi_new
cd rtlwifi_new
make
sudo make install
Reboot and then
Parameter Setting
sudo modprobe -rv rtl8723be
sudo modprobe -v rtl8723be ant_sel=1
Test wireless, if no change then
sudo modprobe -v rtl8723be ant_sel=2
Test wireless again, one or the other should result in better reception
When you find that one works better than the other
echo "options rtl8723be ant_sel=X" | sudo tee /etc/modprobe.d/rtlbtcoex.conf
Where X is 1 or 2- whatever resulted in better performance, in the case of Swapnil Sharma it would be
echo "options rtl8723be ant_sel=1" | sudo tee /etc/modprobe.d/rtlbtcoex.conf
Then the parameter will be remembered following a restart
Jeremy31
- 13,293
