This condition is associated with: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1240940
I am using a rlt8723 wifi card with Kubuntu 15.10.
The card is configured as shown:
ifconfig:
wlp3s0    Link encap:Ethernet  HWaddr 70:77:81:32:3b:17
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
iwconfig:
wlp3s0    IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Retry short limit:7   RTS thr=2347 B   Fragment thr:off
          Power Management:off
results of rfkill list wifi are
0: phy0: Wireless LAN
         Soft blocked: no
         Hard blocked: no
lsmod|grep rtl8723 shows:
rtl8723be              86016  0
btcoexist              53248  1 rtl8723be
rtl8723_common         24576  1 rtl8723be
rtl_pci                28672  1 rtl8723be
rtlwifi                77824  2 rtl_pci,rtl8723be
mac80211              733184  3 rtl_pci,rtlwifi,rtl8723be
however net-manager does not detect wireless networks and running
iwlist wlps30 scan as root gives "no results".
If I boot into Windows 10, there are multiple networks detected,hardware working correctly.
Network manager settings from wireless info tool:
`##### network managers ##################
Installed:
NetworkManager
Running:
root       784     1  0 19:56 ?        00:00:02 /usr/sbin /NetworkManager --no-daemon
##### NetworkManager info ###############
GENERAL.DEVICE:                         wlp3s0
GENERAL.TYPE:                           wifi
GENERAL.NM-TYPE:                        NMDeviceWifi
GENERAL.VENDOR:                         Realtek   Semiconductor Co., Ltd.
GENERAL.PRODUCT:                        RTL8723BE PCIe Wireless Network Adapter
GENERAL.DRIVER:                         rtl8723be
GENERAL.DRIVER-VERSION:                 4.2.0-23-generic
GENERAL.FIRMWARE-VERSION:               N/A
GENERAL.HWADDR:                         <MAC 'wlp3s0' [IF]>
GENERAL.MTU:                            0
GENERAL.STATE:                          30 (disconnected)
GENERAL.REASON:                         42 (The supplicant is now available)
GENERAL.UDI:                            /sys/devices/pci0000:00/0000:00:1c.2/0000:03:00.0/net/wlp3s0
GENERAL.IP-IFACE:
GENERAL.IS-SOFTWARE:                    no
GENERAL.NM-MANAGED:                     yes
GENERAL.AUTOCONNECT:                    yes
GENERAL.FIRMWARE-MISSING:               no
GENERAL.PHYS-PORT-ID:                   --
GENERAL.CONNECTION:                     --
GENERAL.CON-UUID:                       --
GENERAL.CON-PATH:                       --
CAPABILITIES.CARRIER-DETECT:            no
CAPABILITIES.SPEED:                     unknown
CAPABILITIES.IS-SOFTWARE:               no
WIFI-PROPERTIES.WEP:                    yes
WIFI-PROPERTIES.WPA:                    yes
WIFI-PROPERTIES.WPA2:                   yes
WIFI-PROPERTIES.TKIP:                   yes
WIFI-PROPERTIES.CCMP:                   yes
WIFI-PROPERTIES.AP:                     yes
WIFI-PROPERTIES.ADHOC:                  yes
WIFI-PROPERTIES.2GHZ:                   yes
WIFI-PROPERTIES.5GHZ:                   no
CONNECTIONS.AVAILABLE-CONNECTION-PATHS:
SSID  BSSID  MODE  CHAN  FREQ  RATE  SIGNAL  BARS  SECURITY  ACTIVE  *
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########`
Is there another setting which needs to be configured?
Update 1/20/2016: using linux-image-4.2.0-25 tried loading rtl8723be module with: modprobe -v rtl8723be ant_sel=1
and
modprobe -v rtl8723be ant_sel=2
no success in getting WIFI card to detect networks. for reference see
https://github.com/lwfinger/rtlwifi_new/issues/34
I was able to successfully scan for networks after completing the steps below on an HP 11" Pavilion X360 model 11-k020nr. Apparently the rtl8723 can have two antenna but HP only installs one in the laptop. The rtl8723be driver needs to have the correct antenna assigned or the wifi reception is too poor to detect networks.
download drive source files at: https://github.com/lwfinger/rtlwifi_new
There is a "Download Zip" button, in the top 1/3 of the web-page on the right side.
Extract the .zip into any folder. A "rtlwifi_new-master" folder will be created.
Enter the "rtlwifi_new-master" folder and run:
make clean sudo make install
Once the code is compiled and installed:
sudo modprobe -r rtl8723be sudo modprobe -v rtl8723be isp=0 ant_sel=2
run
sudo iwlist wlp3s0 scan
to see if networks are detected. One might have to try ant_sel=1. I confirmed that Bluetooth still works.
If it helps, make it permanent:
sudo -i echo "options rtl8723be isp=0 ant_sel=1" >> /etc/modprobe.d/rtl8723be.conf exit
