Wifi disables abruptly. Tried the solution available on the internet.None worked.Need to disable and enable wifi to start the connection. Cant upgrade to Ubuntu 18.04 as download stops due to wifi issue.Need help.
output after running lspci command:
$ lspci -knn | grep -i net -A3
02:00.1 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 12)
        Subsystem: ASUSTeK Computer Inc. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1043:200f]
        Kernel driver in use: r8169
        Kernel modules: r8169
03:00.0 Network controller [0280]: Ralink corp. RT3290 Wireless 802.11n 1T/1R PCIe [1814:3290]
        Subsystem: Foxconn International, Inc. RT3290 Wireless 802.11n 1T/1R PCIe [105b:e055]
        Kernel driver in use: rt2800pci
        Kernel modules: rt2800pci
pomsky
  • 70,557
Installation of Ralink RT3290
  • fork this repo
  • cd into it
  • compile the driver
  • install the driver
comand for that (it will ask your user password to apply changes to system):
git clone https://github.com/pkeeper/rt3290sta.git
cd rt3290sta
make
sudo make install
sudo modprobe -r rt2800pci
sudo modprobe rt3290sta
Now you need to make it load on startup. Blacklist the rt2800pci driver in /etc/modprobe.d/blacklist.conf and add rt3290sta to /etc/modules.
abu_bua
  • 11,313
