40
Whenever I am trying to get the update I am getting the error at the last line:
Ign http://in.archive.ubuntu.com trusty-updates/multiverse Translation-en_IN
Ign http://in.archive.ubuntu.com trusty-updates/restricted Translation-en_IN
Ign http://in.archive.ubuntu.com trusty-updates/universe Translation-en_IN
Ign http://in.archive.ubuntu.com trusty-backports/main Translation-en_IN
Ign http://in.archive.ubuntu.com trusty-backports/multiverse Translation-en_IN
Ign http://in.archive.ubuntu.com trusty-backports/restricted Translation-en_IN
Ign http://in.archive.ubuntu.com trusty-backports/universe Translation-en_IN
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
And then according to the prompted error when I run:
$ sudo dpkg --configure -a
dpkg: error: parsing file '/var/lib/dpkg/updates/0009' near line 0:
 newline in field name `#padding'
What now? Can I get out of the error?
I tried this link.
You referred a wrong link. Try the below commands on terminal to remove all the files inside /var/lib/dpkg/updates directory ,
cd /var/lib/dpkg/updates
sudo rm *
And then run the below command to get newer ones,
sudo apt-get update
Avinash Raj
  • 80,446
It works for me! I was trying to install the wireless driver when this error came. Had to delete the files and also the lock files.
sudo rm /var/lib/apt/lists/lock
sudo rm /var/cache/apt/archives/lock
sudo rm *
sudo apt-get update
and then you can run your apt-get install to whatever package you want to install
Aerosum
  • 311
