I'm getting the following error on running sudo apt-get update :
sudo apt-get update
Get:1 http://dl.google.com stable InRelease
100% [1 InRelease gpgv 3,435 B] [Connecting to in.archive.ubuntu.com] [ConnectiSplitting up /var/lib/apt/lists/partial/dl.google.com_linux_talkplugin_deb_dists_stable_InReleaseIgn http://dl.google.com stable InRelease
E: GPG error: http://dl.google.com stable InRelease: Clearsigned file isn't valid, got 'NODATA' (does the network require authentication?)
I tried:
$ cd /var/lib/apt
$ sudo mv lists lists.old
$ sudo mkdir -p lists/partial
$ sudo apt-get update
But still getting the same error. Never faced this problem before. I was trying to install texlive-full and ran out of space during installation, apt-get install wasn't working then and gave the following output:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
As per the answer here: Message 'E:dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.' I tried:
cd /var/lib/dpkg/updates
sudo rm *
sudo apt-get update
And then this error occured. Now apt-get install is working fine but update isn't working. What is the solution?
