(First off this is my first linux download to a virtual machine)
Basically I followed a step by step YouTube guide I installed everything until the updates There were originally 1300 updates Now there are 222 updates left Whenever I try to update them I get the "you must manually run 'dpkg --configure -a' " dialog Seems simple enough. I had to do that twice before. However, whenever I go to terminal and click on it it just loads on the upper right and then it never opens. Is there a workaround to this? OR solution?
Bridge
If you can't get to the terminal at all. You can always use 1 of the 6 tty sessions. In all Linux distributions, ctrl+alt+F1 will open the first tty session. You can login from there an use it just like the gnome terminal. Then, take a look at the link below.
similar problem
Follow the steps in the answer. It looks like the same problem you are having.
Andrew
  • 817
