25
Been trying to install git-core package for almost more than half a day now. Every time I do, I get this error:
dpkg: error: parsing file '/var/lib/dpkg/available' near line 0:
newline in field name `../../../../../share/pyshared/UpdateManager/Core/__init__.py'
I've also tried running sudo apt-get update and sudo apt-get install --fix-missing. Even tried rebooting and cleaning the apt-get cache, still doesnt work.
Zanna
  • 72,312
The problem is that your /var/lib/dpkg/available file is damaged.
This is not necessarily related to the git or git-core packages. Try to install any other package and they will fail too.
To fix this you have to delete/clear the file using the command:
sudo dpkg --clear-avail
then rebuild the file using the command:
sudo apt-get update
Now you should be able to install git and git-core.
Lesmana
  • 18,754
From the below error,it was clearly shown that your /var/lib/dpkg/available file was corrupted.
Solution for the above problem is to replace the current /var/lib/dpkg/available file with another /var/lib/dpkg/available-old backup file.
sudo rm /var/lib/dpkg/available
sudo cp /var/lib/dpkg/available-old /var/lib/dpkg/available
Now try,
sudo apt-get update
sudo apt-get install -f
Avinash Raj
  • 80,446
