When I run sudo apt-get update or sudo apt-get upgrade this error appears
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
and when I run sudo dpkg --configure -a, the laptop restarts and freezes at startup when the Ubuntu word is displayed, I just force close it by the power button and then reopen it.
I use Ubuntu 14.04 LTS dual booted with windows 8.1.
user unknown
  • 6,892
Try this on terminal to remove all
cd /var/lib/dpkg/updates
sudo rm *
And then run the below command to get newer ones,
sudo apt-get update
