While attempting to install a package via apt-get the following. The first error I get is:
    E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
And, if I run that command the box spins out of control and I get the following in /var/log/syslog
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398546] ------------[ cut here ]------------
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398552] WARNING: at /build/buildd/linux-3.0.0/arch/x86/xen/multicalls.c:182 xen_mc_flush+01c0()
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398561] Modules linked in: acpiphp
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398568] Pid: 31063, comm: java Tainted: G      D W   3.0.0-14-virtual #23-Ubuntu
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398576] Call Trace:
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398580]  [<c0648265>] ? printk+0x2d/0x2f
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398586]  [<c0150462>] warn_slowpath_common+0x72/0xa0
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398593]  [<c0104883>] ? xen_mc_flush+0x1b3/0x1c0
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398599]  [<c0104883>] ? xen_mc_flush+0x1b3/0x1c0
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398605]  [<c01504b2>] warn_slowpath_null+0x22/0x30
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398611]  [<c0104883>] xen_mc_flush+0x1b3/0x1c0
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398617]  [<c0104e7a>] ? xen_extend_mmu_update+0x4a/0x70
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398624]  [<c0106565>] xen_set_pud_hyper+0x75/0x80
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398630]  [<c01065b9>] xen_set_pud+0x49/0x60
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398636]  [<c0132105>] pud_populate+0x45/0x60
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398642]  [<c0208a24>] __pmd_alloc+0x74/0x90
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398648]  [<c0208cb7>] handle_mm_fault+0x277/0x2c0
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.398655]  [<c065f45b>] do_page_fault+0x15b/0x4a0
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.401923]  [<c020ba24>] ? remove_vma+0x44/0x60
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.401923]  [<c020d9b6>] ? sys_mmap_pgoff+0x106/0x1c0
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.401923]  [<c065f300>] ? vmalloc_fault+0x190/0x190
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.401923]  [<c065c79f>] error_code+0x67/0x6c
Aug 29 20:21:08 ip-10-202-191-4 kernel: [20571563.401923] ---[ end trace 0b105e2a179ad013 ]---
Jonathan
The problem is that the script responsible for setting up the package(either the preinst or the postinst) has a command that causes a kernel panic, or just a kernel oops. Therefore, we must clean out the bad package to keep it from trying to run through dpkg and cause a crash again. To to so, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the commands below, one by one.
sudo rm /var/lib/apt/lists/lock
sudo cp -arf /var/lib/dpkg /var/lib/dpkg.backup
sudo mv /var/lib/dpkg/status /var/lib/dpkg/status-bad
sudo cp /var/lib/dpkg/status-old /var/lib/dpkg/status
sudo mv /var/lib/dpkg/available /var/lib/dpkg/available-bad
sudo cp /var/lib/dpkg/available-old /var/lib/dpkg/available
sudo rm -rf /var/lib/dpkg/updates/*
sudo rm -rf /var/lib/apt/lists
sudo rm /var/cache/apt/*.bin
sudo mkdir /var/lib/apt/lists
sudo mkdir /var/lib/apt/lists/partial
LANG=C;sudo apt-get clean
LANG=C;sudo apt-get autoclean
LANG=C;sudo apt-get --purge autoremove
LANG=C;sudo apt-get update
(The above commands are complements of ObsessiveFOSS)
Once you do that, and all is OK, then proceed with the instructions below on how to install your package.
To install RRDTool, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below. To make sure you have all the required dependencies.
sudo apt-get install libpango1.0-dev libxml2-dev
sudo apt-get install librrds-perl rrdtool
Or you can install it from the Ubuntu Software Center, by clicking below:
If the installation fails again, perform the repair steps listed above and file a bug against the package, stating that either the preinst or the postinst seems to cause a kernel panic.
Mitch
  • 109,787
