I typed something in Bashrc and I can not use commands like cp, gedit, ls, etc. etc anymore. The terminal give me a message like:
Command 'ls' is available in '/bin/ls'
The command could not be located because '/bin' is not included in the PATH environment variable.
ls: command not found
I tried to restore bashrc, but I need to use cp and I can not use this command either:
Command 'cp' is available in '/bin/cp'
cp: command not found
What could I do? Thank you.
muru
  • 207,228
ogs
  • 71
It looks like your PATH variable got messed up.
If this ever happens to you, and you are running a /bin/sh (or variant such as /bin/bash)....enter the following on the command line:
 export PATH=/bin:/usr/bin:/usr/local/bin:/sbin:/usr/sbin
Then you will be able to easily use the base UNIX commands without having to prefix them with /....blah..../command while you are fixing the problem.
Jeremy Kerr
  • 27,829
mdpc
  • 1,219
