It's been awhile since I've used my Kubuntu system. I'm trying to upgrade to version 16.04 - and running into a series of problems:
  1. When attempting to upgrade Kubuntu to version 16.04, I get the error message:
    Required depends is not installed
    The required dependency 'apt (>= 1.0.1ubuntu2.13)' is not installed.
  2. So, when I attempt to fix that in the (Konsole) Terminal, I enter:
    sudo apt-get install --only-upgrade apt
    The response that I get is:
    Command 'sudo' is available in '/usr/bin/sudo'
    The command could not be located because '/usr/bin' is not included in the PATH environment variable.
    sudo: command not found
  3. I then try to fix that by entering:
    apt-get install sudo
    The response that I get to this is:
    Command 'apt-get' is available in '/usr/bin/apt-get'
    apt-get: command not found
  4. I tried to address that by entering:
    export PATH=/usr/bin:/bin
    In response, I get:
    E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
    E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
  5. In order to identify what might be causing the problem, I ran:
    ps aux | grep apt
    The only thing that comes up that looks like it might be a possibility is this:
    4381  0.0  0.0  11740   936 pts/2    S+   23:50   0:00 grep --color=auto apt
(All the other "apt"s it finds are part of "caption"...)
At this point, where should I go? What should I try?
Kulfy
  • 18,154
csm101
