49
Can someone tell me why I get this error when I try to add a repository and what if anything I can do about it?
When I try to add a repository using:
sudo add-apt-repository ppa:upubuntu-com/tor
I get the following error:
Command 'sudo' is available in '/usr/bin/sudo'
The command could not be located because '/usr/bin' is not included in the PATH
environment variable.
sudo: command not found
jkt123
  • 3,600
Your PATH variable has been messed up. Unless you are trying to run a restricted user with rbash, you should have /usr/bin in $PATH. For a terminal session you can fix this by running:
export PATH="/usr/bin:$PATH"
As @SylvainPineau mentioned, this answer covers how to permanently fix your path by editing the /etc/environment file.
jkt123
  • 3,600
