Command 'make' is available in '/usr/bin/make'
The command could not be located because '/usr/bin' is not included in the
PATH environment variable.
make: command not found
It happened after I did this:
export PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/cc1/:$PATH
After I copied and paste it it automatically executed in the terminal after realizing my mistake I corrected like this below.
export PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/cc1/bin:$PATH
It isn't just make:
Command 'whoami' is available in '/usr/bin/whoami' The command could not be located because '/usr/bin' is not included in the PATH environment variable.
whoami: command not found
Tim
  • 33,500
The T
  • 111
You need to include the folders where commands can be found in the PATH environment variable. So it sounds like your PATH environment variable is missing the /usr/bin entry. What is the output of echo $PATH for your system?
The default for Ubuntu 14.04 is /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games and you can restore this by simply running
export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
Then you should be able run the command you tried in the first place to add the paths, or to add them all at once you can simply run...
export PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/cc1/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
I hope this helps!
Try this:
export PATH+=:/usr/lib/gcc/x86_64-linux-gnu/4.6/cc1/bin
Also, you should consider adding it to .bashrc if you want to make it a part of $PATH every time you open a terminal.
