40
Reading these questions and answers:
brought me another one that will create problems for new users of that command:
  • How to configure pkexec for easy usage?
For example when doing the following:
(Opening a file in terminal)
pkexec nano /etc/mysql/my.cnf
(Opening a file in GUI)
pkexec gedit /etc/mysql/my.cnf
The last one gets the following error:
 pkexec must be setuid root
Now this brought me the following questions:
  1. How to configure pkexec to avoid getting this? Similar to how sudo/gksu behave when doing the same thing (they only ask for the password).
  2. If applicable, how to tell it to not ask for a password after the first time applying it to a command (or including the first command if configurable)?
  3. Where to save the configuration file if not yet existing?
  4. Is there a GUI app to configure pkexec usage (Policy Kit)?
Luis Alvarado
  • 216,643
How to configure pkexec to avoid getting errors when run GUI applications?
I found two possible ways:
  1. As you can see, using the following:
    pkexec env DISPLAY=$DISPLAY XAUTHORITY=$XAUTHORITY gedit
    will not get you any error. And this is normal because man pkexec is very clear in this matter:
           [...] pkexec will not allow you to run X11 applications
           as another user since the $DISPLAY and $XAUTHORITY environment
           variables are not set.[...]
    As result you can create an (permanent) alias (this is the simpliest way):
    alias pkexec='pkexec env DISPLAY=$DISPLAY XAUTHORITY=$XAUTHORITY'
  2. Or, (again) as man pkexec says:
           [...] These two variables will be retained if the
           org.freedesktop.policykit.exec.allow_gui annotation on an action is set
           to a nonempty value; this is discouraged, though, and should only be
           used for legacy programs.[...]
    you can create a new policy file in /usr/share/polkit-1/actions named com.ubuntu.pkexec.gedit.policy with the following xml code inside where the most important thing is to set org.freedesktop.policykit.exec.allow_gui to a nonempty value:
    <?xml version="1.0" encoding="UTF-8"?>
    <!DOCTYPE policyconfig PUBLIC
      "-//freedesktop//DTD PolicyKit Policy Configuration 1.0//EN"
      "http://www.freedesktop.org/standards/PolicyKit/1/policyconfig.dtd">
    <policyconfig>
      <action id="com.ubuntu.pkexec.gedit">
        <message gettext-domain="gparted">Authentication is required to run gedit</message>
        <icon_name>gedit</icon_name>
        <defaults>
          <allow_any>auth_admin</allow_any>
          <allow_inactive>auth_admin</allow_inactive>
          <allow_active>auth_admin</allow_active>
        </defaults>
        <annotate key="org.freedesktop.policykit.exec.path">/usr/bin/gedit</annotate>
        <annotate key="org.freedesktop.policykit.exec.allow_gui">true</annotate>
      </action>
    </policyconfig>
How to tell it to not ask for a password after the first time applying it to a command?
For these three setting tags: allow_any, allow_inactive and allow_active from the policy file, the following options are available:
  • no: The user is not authorized to carry out the action. There is therefore no need for authentication.
  • yes: The user is authorized to carry out the action without any authentication.
  • auth_self: Authentication is required but the user need not be an administrative user.
  • auth_admin: Authentication as an administrative user is require.
  • auth_self_keep: The same as auth_self but, like sudo, the authorization lasts a few minutes.
  • auth_admin_keep: The same as auth_admin but, like sudo, the authorization lasts a few minutes.
     Source: Polkit - Structure - Actions
So, if you use auth_admin_keep option (or, as applicable, auth_self_keep), pkexec will not ask for a password again for some time (by default this time is set to 5 minutes as I checked). The disadvantage here is that this thing is applicable only for one - the same - command / application and valid for all users (unless if it is overruled in later configuration).
Configuration files or polkit definitions can be divided into two kinds:
  • Actions are defined in XML .policy files located in /usr/share/polkit-1/actions. Each action has a set of default permissions attached to it (e.g. you need to identify as an administrator to use the GParted action). The defaults can be overruled but editing the actions files is NOT the correct way. The name of this policy file should have this format:
    com.ubuntu.pkexec.app_name.policy
  • Authorization rules are defined in JavaScript .rules files. They are found in two places: 3rd party packages can use /usr/share/polkit-1/rules.d (though few if any do) and /etc/polkit-1/rules.d is for local configuration. The .rules files designate a subset of users, refer to one (or more) of the actions specified in the actions files and determine with what restrictions these actions can be taken by that/those user(s). As an example, a rules file could overrule the default requirement for all users to authenticate as an admin when using GParted, determining that some specific user doesn't need to. Or isn't allowed to use GParted at all.
Is there a GUI application to configure pkexec usage?
From what I know, until now (18.01.2014) doesn't exist something like this. If in the future I will find something, I will not forget to update this answer too.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
In addition to Radu's answer: I would not use the alias pkexec, but gksudo.
Why? You don't need to rewrite your script.
I use the following configuration:
  • open a terminal
  • cd /usr/local/bin
  • sudo gedit gksudo (create new file called "gksudo"
  • write the following content:
    • pkexec env DISPLAY=$DISPLAY XAUTHORITY=$XAUTHORITY $@
    • (don't forget the $@ at the end. This is for redirecting all parameters)
  • save and quit
  • make the file executable: chmod 755 gksudo
  • Now you should have a fully functional gksudo command available on your system - permanently.
For documentation reasons, I will write, what I tried and didn't work out:
  • alias pkexec='pkexec env [...]'
  • alias gksudo='pkexec [...]'
    • Was not permanent and did only stay in one single terminal
  • adding the alias to ~/.bash_aliases
    • Works if you first open a terminal. Does not work, if you doubleclick scripts
  • Create a link to pkexec with parameters ( ln -s pkexec [...])
    • After a quick googleing, it seems like linux doesn't support parameters in links
DarkTrick
  • 609
As opposed to @Radu Rădeanu answer, mine explains how to create the pkexec command and configure it in order to work as gksu!
So, the main alternative for the GUI version of sudo is to use the pkexec command, but for that you need to export certain environment variables at the moment of execution, which can be done by adding the following aliase to your ~/.bashrc file:
alias gksu='pkexec env DISPLAY=$DISPLAY XAUTHORITY=$XAUTHORITY DBUS_SESSION_BUS_ADDRESS=$DBUS_SESSION_BUS_ADDRESS'
Now in order to use it, you can run something like the following command:
# structure: gksu <cmd>
$ gksu /usr/bin/my_app
References:
