I'm trying to create a desktop shortcut that changes my monitor input by executing sudo /usr/bin/ddcutil -d 1 setvcp 60 0xF without requiring a password. I've made an entry in the sudoers.d directory and if the command is run from the terminal no password is required as expected, but when I click on the shortcut it prompts for a password. How what needs to be done to make this shortcut run without a password?
.desktop file:
[Desktop Entry]
Encoding=UTF-8
Type=Application
Name=Windows 10
Comment=Switch Display to Windows Virtual Machine
Icon=/usr/share/icons/windows-icon.png
Terminal=true
Exec=sudo /usr/bin/ddcutil -d 1 setvcp 60 0xF
sudoers file:
myusername ALL = NOPASSWD: /usr/bin/ddcutil
The solution here doesn't work because gksu is deprecated and using pkexec instead as suggested in one of the answers still prompts for a password.
ks0ze
  • 141
The solution seems to be using pkexec with a PolicyKit configuration. This answer covers more details on the PolicyKit settings. It is geared towards executing GUI applications without requiring a password but mostly applies to non-graphical applications as well.
For my case, the .desktop file was updated to replace sudo with pkexec. Terminal= can be set to either true or false:
[Desktop Entry]
Encoding=UTF-8
Type=Application
Name=Windows 10
Terminal=false
Exec=pkexec /usr/bin/ddcutil -d 1 setvcp 60 0xF
Then, a PolicyKit entry had to be made at /usr/share/polkit-1/actions/com.ubuntu.pkexec.ddcutil.policy:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE policyconfig PUBLIC
  "-//freedesktop//DTD PolicyKit Policy Configuration 1.0//EN"
  "http://www.freedesktop.org/standards/PolicyKit/1/policyconfig.dtd">
<policyconfig>
<action id="com.ubuntu.pkexec.ddcutil"> <defaults> <allow_active>yes</allow_active> </defaults> <annotate key="org.freedesktop.policykit.exec.path">/usr/bin/ddcutil</annotate> </action>
</policyconfig>
/var/log/auth.log seems to be where PolicyKit messages are logged if needed for debugging.
ks0ze
  • 141
made this work by adding the full command to the sudoers file
myusername ALL = NOPASSWD:/usr/bin/ddcutil -d 1 setvcp 60 0xF
