I installed Ubuntu 12.10, then installed Nemo. Now I would like to make Nemo the default file manager. I've searched the web for a solution but every time I restart my computer Nautilus come back.
Does anyone know an effective solution?
There is a much better way to do this without moving files and setting links. Just open a terminal with CTRL+ALT+T and perform this command:
xdg-mime default nemo.desktop inode/directory application/x-gnome-saved-search
Then set up Nemo to handle your desktop:
gsettings set org.gnome.desktop.background show-desktop-icons false
gsettings set org.nemo.desktop show-desktop-icons true
Revert this changes:
gsettings set org.gnome.desktop.background show-desktop-icons true
gsettings set org.nemo.desktop show-desktop-icons false
xdg-mime default nautilus.desktop inode/directory application/x-gnome-saved-search
Open your terminal with CTRL+ALT+T and then paste this:
sudo mv /usr/bin/nautilus /usr/bin/nautilus.back && sudo ln -s /usr/bin/nemo /usr/bin/nautilus
then try again, hope that helps.
Note that this will effectively make Nautilus inaccessible on your system unless you modify shortcuts to point to nautilus.back.
Here's what worked for me on 18.04 (source here):
If you have Nemo installed on your system and want to set Nemo as the default file manager, run this command in a terminal:
To revert this, enter
Nemo (the nemo.desktop app launcher to be exact) should now be the default file manager. To test the result, run this command:
xdg-open $HOME
That command should launch Nemo showing your home directory.
