Ubuntu 22.10 and newer
Installation still works the same as with previous versions. However, after installing, you'll need to open nautilus preferences (ctrl + ,) and disable the new Search on type ahead option that is checked by default - this way you have the option to return to the default search behavior later if you wish.
These versions also do away with the text field that used to pop up in the bottom right corner when typing.
Ubuntu 18.04 until 22.04
Well, this issue has motivated me enough to finally check out Ubuntu's PPA submission process; you can find Nautilus packages with the Arch community patch applied here: https://launchpad.net/~lubomir-brindza/+archive/ubuntu/nautilus-typeahead
and install it by running:
sudo add-apt-repository ppa:lubomir-brindza/nautilus-typeahead
sudo apt upgrade
# or, if you don't want to upgrade any other packages:
sudo apt install nautilus
I'd just like to clarify the "Someone took it, compiled for Ubuntu and made a PPA" part in the top post - that's really not how PPA works. The actual way this works is that you provide a patch that adds/changes the desired functionality (typeahed in this case), and add it on top of all the other Ubuntu-specific patches you get when you download the source package using apt-get source nautilus. Once that's done and you've updated the changelog, debuild will create digitally signed files that describe what exactly changed with regards to the upstream source package. Only those are ever uploaded to Launchpad, which then attempts to compile and build the package. The changes to the upstream are reviewable in the Launchpad interface.
TL;DR: one does not upload the complete source code nor binaries directly to Launchpad nor PPA repository. Just wanted to clarify that, in case anyone was wary of something shady happening.
