Python virtual environments are used to create isolated python environments to avoid dependency and version conflicts, and also indirectly take care of permission issues. But what is the easiest way to set it up, and use it, in Ubuntu?
With virtualenvwrapper (user friendly wrappers for the functionality of virtualenv)
Install virtualenv
Install virtualenv with
sudo apt install virtualenv
Install virtualenvwrapper
The reason we are also installing virtualenvwrapper is because it offers nice and simple commands to manage your virtual environments. There are two ways to install virtualenvwrapper:
As Ubuntu package (from Ubuntu 16.04)
Run
sudo apt install virtualenvwrapper
then run
echo "source /usr/share/virtualenvwrapper/virtualenvwrapper.sh" >> ~/.bashrc
Using pip
Install and/or update pip
Install pip for Python 2 with
sudo apt install python-pipor for Python 3
sudo apt install python3-pip(if you use Python 3, you may need to use
pip3instead ofpipin the rest of this guide).Optional (but recommended): Turn on bash autocomplete for pip
Run
pip completion --bash >> ~/.bashrcand run
source ~/.bashrcto enable.Install virtualenvwrapper
Because we want to avoid
sudo pipwe installvirtualenvwrapperlocally (by default under~/.local) with:pip install --user virtualenvwrapperand
echo "export VIRTUALENVWRAPPER_PYTHON=/usr/bin/python3" >> ~/.bashrcSource virtualenvwrapper in
.bashrcecho "source ~/.local/bin/virtualenvwrapper.sh" >> ~/.bashrc
Setup virtualenv and virtualenvwrapper:
First we export the WORKON_HOME variable which contains the directory in which our virtual environments are to be stored. Let's make this ~/.virtualenvs
export WORKON_HOME=~/.virtualenvs
now also create this directory
mkdir $WORKON_HOME
and put this export in our ~/.bashrc file so this variable gets automatically defined
echo "export WORKON_HOME=$WORKON_HOME" >> ~/.bashrc
We can also add some extra tricks like the following, which makes sure that if pip creates an extra virtual environment, it is also placed in our WORKON_HOME directory:
echo "export PIP_VIRTUALENV_BASE=$WORKON_HOME" >> ~/.bashrc
Source ~/.bashrc to load the changes
source ~/.bashrc
Test if it works
Now we create our first virtual environment. The -p argument is optional, it is used to set the Python version to use; it can also be python3 for example.
mkvirtualenv -p python2.7 test
You will see that the environment will be set up, and your prompt now includes the name of your active environment in parentheses. Also if you now run
python -c "import sys; print sys.path"
you should see a lot of /home/user/.virtualenv/... because it now doesn't use your system site-packages.
You can deactivate your environment by running
deactivate
and if you want to work on it again, simply type
workon test
Finally, if you want to delete your environment, type
rmvirtualenv test
Enjoy!
Thanks to the author of this blogpost.
- 9,559
Virtual environments offer a way for managing and isolating dependencies on a per-project basis. Moreover, they also avoid the whole sudo pip install situation, which is a security risk as I have explained in https://askubuntu.com/a/802594/15003. The official Python documentation also encourages the use of virtual environments.
The easiest way to create and use virtual environments for both Python 2 and Python 3 is to install virtualenv using apt or apt-get. For each Python project, create a virtualenv and then activate it. Note that the virtualenv is specific for a particular Python version. After activation, use pip to install Python packages as usual regardless of whether you are using Python 2 or 3; there is no need to use pip3 for Python 3. sudo is only used to install virtualenv and is not used with pip, therefore avoiding the aforementioned security risk. The commands to do so are:
sudo apt update
cd ~/desired_directory # cd to desired_directory
virtualenv venv # create virtualenv named venv for default system Python, which is Python 2 for Ubuntu
source venv/bin/activate # activate virtualenv
pip install -U pip # upgrade pip in case it is outdated
pip install desired_package # install desired_package
If you would like to create a virtualenv for Python 3, replace virtualenv venv with:
virtualenv venv -p python3
Read more about various bells and whistles for virtualenv at https://virtualenv.pypa.io/en/stable/.
- 24,109
With the venv module available from Python 3.3 (and Ubuntu 15.10)
Virtual environments (venvs) are so popular that the functionality is now included in python itself (from 3.3 onwards). To use it on Ubuntu you need to install python3-venv (since the ensurepip module is not available):
sudo apt-get install python3-venv
After that you can use
pyvenv myvirtualenv
to create a virtual environment called myvirtualenv. You can then use
source myvirtualenv/bin/activate
to activate the virtual environment. To deactivate simply type
deactivate
EDIT:
The pyvenv script has been deprecated in favour of python3 -m venv. This prevents confusion as to what Python interpreter pyvenv is connected to and thus what Python interpreter will be used by the virtual environment. (source)
- 9,559
It's easy, you install python-virtualenv. Then you can create a virtualenv with the virtualenv command. See their documentation for more.
- 8,106
