I am trying to remove python but I am being told it will remove almost all my packages install (exaggeration). How can I just remove python 3.8 and not all the other packages?
hutber@hutber:/var/www$ sudo apt-get purge python3.8
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libexpat1-dev libgsf-bin libmspack0 libpython3-dev libpython3.8-dev libxmlsec1-openssl python-pip-whl zerofree zlib1g-dev
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  libutempter0 xterm
Suggested packages:
  xfonts-cyrillic
The following packages will be REMOVED:
  apparmor* apt-clone* aptdaemon* apturl* apturl-common* blueberry* bulky* caribou* celluloid* cinnamon* cinnamon-common* cinnamon-control-center* cinnamon-control-center-dbg*
  cinnamon-dbg* cinnamon-desktop-data* cinnamon-screensaver* cinnamon-session* cinnamon-settings-daemon* command-not-found* dkms* drawing* firefox* foomatic-db-compressed-ppds*
  gdebi* gdebi-core* gir1.2-cinnamondesktop-3.0* gir1.2-meta-muffin-0.0* gir1.2-xapp-1.0* gnome-menus* gnome-online-accounts* gnome-terminal* gufw* gvfs-backends* hplip*
  hplip-data* hypnotix* libcinnamon-desktop-dbg* libcinnamon-desktop4* libmpv1* libsmbclient* libxapp1* lightdm-settings* lsb-release* mint-common* mint-meta-cinnamon*
  mint-meta-core* mintbackup* mintdrivers* mintinstall* mintlocale* mintmenu* mintreport* mintsources* mintstick* mintsystem* mintupdate* mintwelcome* nemo* nemo-data*
  nemo-dbg* nemo-fileroller* nemo-preview* nemo-share* netplan.io* network-manager-gnome* networkd-dispatcher* nvidia-prime-applet* onboard* onboard-common* open-vm-tools*
  open-vm-tools-desktop* openprinting-ppds* orca* pix* pix-dbg* plymouth-theme-ubuntu-text* printer-driver-foo2zjs* printer-driver-foo2zjs-common* printer-driver-m2300w*
  printer-driver-postscript-hp* printer-driver-ptouch* printer-driver-pxljr* printer-driver-sag-gdi* python3* python3-apport* python3-apt* python3-aptdaemon*
  python3-aptdaemon.gtk3widgets* python3-blinker* python3-brlapi* python3-bs4* python3-cairo* python3-certifi* python3-cffi-backend* python3-chardet* python3-click*
  python3-colorama* python3-commandnotfound* python3-configobj* python3-crypto* python3-cryptography* python3-cups* python3-cupshelpers* python3-dbus* python3-debian*
  python3-defer* python3-dev* python3-distro* python3-distutils* python3-entrypoints* python3-gdbm* python3-gi* python3-gi-cairo* python3-grpcio* python3-httplib2* python3-icu*
  python3-idna* python3-ifaddr* python3-imdbpy* python3-jwt* python3-keyring* python3-launchpadlib* python3-lazr.restfulclient* python3-lazr.uri* python3-ldb* python3-lib2to3*
  python3-linecache2* python3-louis* python3-macaroonbakery* python3-magic* python3-mako* python3-markupsafe* python3-nacl* python3-netaddr* python3-netifaces*
  python3-oauthlib* python3-packaging* python3-pam* python3-parted* python3-pbr* python3-pexpect* python3-pil* python3-pip* python3-pkg-resources* python3-problem-report*
  python3-protobuf* python3-psutil* python3-ptyprocess* python3-pyatspi* python3-pycurl* python3-pyinotify* python3-pymacaroons* python3-pyparsing* python3-reportlab*
  python3-reportlab-accel* python3-requests* python3-requests-file* python3-requests-unixsocket* python3-rfc3339* python3-samba* python3-secretstorage* python3-setproctitle*
  python3-setuptools* python3-simplejson* python3-six* python3-soupsieve* python3-speechd* python3-systemd* python3-talloc* python3-tdb* python3-testresources*
  python3-tinycss2* python3-tldextract* python3-traceback2* python3-tz* python3-unidecode* python3-unittest2* python3-uno* python3-urllib3* python3-wadllib*
  python3-webencodings* python3-wheel* python3-xapp* python3-xdg* python3-xkit* python3-xlib* python3-xlrd* python3-yaml* python3.8* python3.8-dev* redshift-gtk*
  rhythmbox-plugin-tray-icon* rhythmbox-plugins* samba-common-bin* samba-libs* slick-greeter* smbclient* sticky* synaptic* system-config-printer* system-config-printer-common*
  system-config-printer-udev* thingy* timeshift* ubuntu-drivers-common* ubuntu-system-adjustments* ufw* warpinator* webapp-manager* xapps-common* xed* xed-dbg* xfsprogs* xorg*
  xreader* xreader-dbg* xserver-xorg* xviewer* xviewer-dbg* xviewer-plugins* yelp* youtube-dl*
The following NEW packages will be installed:
  libutempter0 xterm
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
  mintsources python3-apt (due to mintsources) python3-gi (due to mintsources) python3-gi-cairo (due to mintsources) python3-pycurl (due to mintsources)
  python3-requests (due to mintsources) mint-common (due to mintsources) gir1.2-xapp-1.0 (due to mintsources) lsb-release (due to mintsources)
0 upgraded, 2 newly installed, 222 to remove and 7 not upgraded.
Need to get 773 kB of archives.
After this operation, 512 MB disk space will be freed.
You are about to do something potentially harmful.
To continue type in the phrase 'Yes, do as I say!'
 ?] ^C
A modern linux desktop is build largely using python. You can remove python, but then you also remove the desktop. There is no way around. You can not remove the foundations without taking down the house as well.
vanadium
  • 97,564
