I recently updated my python release from 3.8 to 3.10, using
sudo update-alternatives --config python3, but this seems to have caused a problem with apt somewhere. Whenever I try to run sudo apt-get update it works as expected. When I then try to run sudo apt-get upgrade, I run into the following problem.
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up python-apt (2.0.0ubuntu0.20.04.6) ...
/var/lib/dpkg/info/python-apt.postinst: 6: pycompile: not found
dpkg: error processing package python-apt (--configure):
installed python-apt package post-installation script subprocess returned error exit status 127
python-apt
When I try to reinstall python apt to fix this problem with sudo apt install --reinstall python-apt, I get the following error.
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
E: Internal Error, No file name for python-apt:amd64
Does anyone know how I can fix this? I am also unable to open the software updater.
