25
On a fresh install of 16.04, I am trying to install virtualenvwrapper by following this great answer by Gerhard Burger.
after configuring the .bashrc, whenever opening the terminal displays
bash: /usr/local/bin/python2.7: No such file or directory
virtualenvwrapper.sh: There was a problem running the initialization hooks.
If Python could not import the module virtualenvwrapper.hook_loader,
check that virtualenvwrapper has been installed for
VIRTUALENVWRAPPER_PYTHON=/usr/local/bin/python2.7 and that PATH is
set properly.
the script location is,
$ sudo find / -name virtualenvwrapper.sh
[sudo] password for john:
/usr/local/bin/virtualenvwrapper.sh
contents of my .bashrc are,
export WORKON_HOME=/home/john/.virtualenvs
source /usr/local/bin/virtualenvwrapper.sh
export PIP_VIRTUALENV_BASE=/home/john/.virtualenvs
here is my pip freeze
cffi==1.5.2
greenlet==0.4.9
pbr==1.10.0
readline==6.2.4.1
six==1.10.0
stevedore==1.15.0
virtualenv==15.0.2
virtualenv-clone==0.2.6
virtualenvwrapper==4.7.1
the python interpreter's location,
$ which python
/usr/bin/python
How do I make it work?
thank you.
5 Answers5
37
I am using Ubuntu server 16.04, You should also export the python interpreter in which you've installed the the virtualenvwrapper
export VIRTUALENVWRAPPER_PYTHON=/usr/bin/python3
export WORKON_HOME=~/.virtualenvs
source /home/vagrant/.local/bin/virtualenvwrapper.sh
Make sure to replace all the paths above according to your own system. Your wrapper script might e.g. be located in /usr/local/bin/virtualenvwrapper.sh instead, or you might use a different interpreter or virtualenvs home, ...
Byte Commander
  • 110,243
In the .bashrc change
and then make it work in the current shell by
Afterwards, change in the virtualenvwrapper.sh
VIRTUALENVWRAPPER_PYTHON="$(command \which python)"
to this
VIRTUALENVWRAPPER_PYTHON="$(command \which python3)"
zx485
  • 2,865
just comment
line in
~/.bashrc
file....it worked for me.
You probably need to update your PYTHONPATH environment variable. In your .bashrc, before all the virtualenvwrapper variables, add the following line:
export PYTHONPATH=${PYTHONPATH}:/usr/bin
αғsнιη
  • 36,350
michael
  • 254
Firstly Cross-verify PATH in .bashrc with following commands:
which virtualenv
which virtualenvwrapper.sh
output of:
echo $VIRTUALENVWRAPPER_PYTHON
and
which python3
should be same which is
/usr/bin/python3
Configure the path accordingly to above results
export MY_PROJECT=~/my_proj
export VIRTUALENVWRAPPER_WORKON_CD=1
export VIRTUALENVWRAPPER_VIRTUALENV='result of which virtualenv'
source 'result of which virtualenvwrapper.sh'
if after verifying path still INITIALIZATION HOOK ERROR REMAINS.
Then, In source left everthing as it is just replace virtualenvwrapper.sh with virtualenvwrapper_lazy.sh
Then it should work
