I installed python virtualenv and virtualenvwrapper on ubuntu 15.10 following the answer at How to set up and use a virtual python environment in Ubuntu?. The installation was successful, i.e. I can create, deactivate and work on my python virtualenvs. However since I installed it, every time I fire up the terminal I get:
bash: WORKON_HOME=~/.virtualenvs: No such file or directory
I checked if the environment variable WORKON_HOME is set correctly by typing:
echo $WORKON_HOME
and I get as output:
~/.virtualenvs
What can I do to remove the error? Thank you
EDIT 1
The output of grep WORKON_HOME ~/.bashrc command is:
echo "export WORKON_HOME=$WORKON_HOME" >> ~/.bashrc
echo "export PIP_VIRTUALENV_BASE=$WORKON_HOME" >> ~/.bashrc
source WORKON_HOME=/home/diego/.virtualenvs
export WORKON_HOME=/home/diego/.virtualenvs
export WORKON_HOME=
export WORKON_HOME=
export WORKON_HOME=
export WORKON_HOME=
export WORKON_HOME=
EDIT 2
I have removed the lines you (@ByteCommander) mentioned. The error does not appear anymore. However, when I edit the .bashrc file, at the end it look like this:
source /usr/local/bin/virtualenvwrapper.sh
export PIP_VIRTUALENV_BASE=/home/diego/.virtualenvs
There are many lines that repeat. Is this normal? Shall I remove the duplicate? Thanks
diegus
  • 487
Okay, there are some wrong lines in your .bashrc file.
Please open ~/.bashrc in your favourite text editor and delete all these lines:
  • All lines that look like this pattern:
    echo "export SOMETHING" >> ~/.bashrc
    This includes e.g. those lines from your grep output:
    export SOMETHING=
    export WORKON_HOME=
  • This line:
If you are not sure whether to delete a line or not, better ask before you permanently remove it. Making a backup copy of the file before starting to delete lines could also be useful.
Byte Commander
  • 110,243
