I am a beginner user in Ubuntu , I have some issue. so please help me.
ghaas0ab@dem0:~$ pip install virtualenv
Requirement already satisfied: virtualenv in /usr/lib/python2.7/dist-packages (15.1.0)
What's mean this message ? and how to install virtualenv?
Thank you,
Aziz
The message means you already have installed virtualenv, so there's no need to install it again.
In order to activate it, try to copy + paste following commands:
virtualenv -p python3 .venv
source .venv/bin/activate
for checking your pip packages:
pip freeze
for deactivating:
deactivate
if this does not work for you try this way:
python3 -m venv .venv
but in this case try to ignore the pkg-resources==0.0.0 in your venv otherwise it will give conflict in requirements, ones you transfer your files to someone else.
sebuhi
  • 129
It means that virtualenv tool is already installed in your local system. Now to activate virtual environment in your laptop, proceed as follows:
Create the virtualenv:
    $ cd <working_dir> # move into the dir where you want to create venv
    $ virtualenv venv
NOTE: If you have both Python 3 and Python 2 installed, try this command instead of virtualenv venv, it creates an isolated Python 3 environment called venv in your current directory
    $ virtualenv venv -p $(which python3)
Run venv:
    $ source venv/bin/activate
Exit:
    (venv)$ deactivate # to exit the environment
