I installed MySQL using sudo apt-get. Now I need to remove it from my system.
How can I do that?
How can I do that?
I assume that you don't need MySQL anymore and you have already taken backup of your important databases. I suggest you to take backup of your important MySQL databases.
Note: Your all mysql data will be lost.
First make sure that MySQL service is stopped.
sudo systemctl stop mysql
Remove MySQL related all packages completely.
sudo apt-get purge mysql-server mysql-client mysql-common mysql-server-core-* mysql-client-core-*
Remove MySQL configuration and data. If you have changed database location in your MySQL configuration, you need to replace /var/lib/mysql according to it.
sudo rm -rf /etc/mysql /var/lib/mysql
(Optional) Remove unnecessary packages.
sudo apt autoremove
(Optional) Remove apt cache.
sudo apt autoclean
all the above solutions are correct but I would try with
sudo apt-get remove --purge mysql* sudo apt-get autoremove sudo apt-get autoclean
This will uninstall all mysql related packages.
This will remove mysql 5.6 from ubuntu 15.04
sudo apt-get remove --purge mysql-server mysql-client mysql-common
sudo rm -rf /var/lib/mysql
First you need to stop your mysql server from service.
sudo service mysql stop
Then You can use purge command to uninstall
Note: the above based on your package list. I have installed both server and client. This will for your convineient
sudo -i
service mysql stop
killall -KILL mysql mysqld_safe mysqld
apt-get --yes purge mysql*
apt-get --yes autoremove --purge
apt-get autoclean
deluser --remove-home mysql
delgroup mysql
rm -rf /etc/apparmor.d/abstractions/mysql /etc/apparmor.d/cache/usr.sbin.mysqld /etc/mysql /var/lib/mysql /var/log/mysql* /var/log/upstart/mysql.log* /var/run/mysqld ~/.mysql_history
updatedb
Based on this answer and many others...
I don't use Ubuntu much but what I think you should try is what I did.
I first typed this in command line : sudo apt-get remove --purge mysql-server mysql-client mysql-common,
then followed with this below : sudo apt-get autoremove
and finally typed this : sudo apt-get autoclean.
I found that it was removed.
I forgot the MySQL root password and needed to reset. I tried this, but it didn't work, because it kept saying "can't write logs" or something similar.
My solution was to completely remove MySQL from Ubuntu 13.10 and fresh installation.
I had to run the last command because Ubuntu sometimes keeps some libs even you try to purge them all.
Now, I use this command to install MySQL server and client:
sudo apt-get install mysql-client mysql-server
Try this, It will fully wipeout out every single file of MySQL from your system:
sudo service mysql stop #or mysqld
sudo killall -9 mysql
sudo killall -9 mysqld
sudo deluser -f mysql
sudo apt-get purge mysql-server-core-5.7
sudo apt-get purge mysql-client-core-5.7
sudo rm -rf /var/log/mysql
When I tried sudo apt-get purge mysql* it didn't work.
Purged mysql5 with:
sudo apt-get purge mysql-*
Then for cleaning up:
