I've just installed Ubuntu 20.04 and messed something up with MySQL. I don't know how to login:
$ mysql -u root -p
Enter password:
ERROR 1698 (28000): Access denied for user 'root'@'localhost'
I don't have any data in there, so I don't care if the DB is lost. In fact, I would prefer a clean solution.
What I tried
dpkg-reconfigure
This answer:
$ sudo dpkg-reconfigure mysql-server-8.0
mysqld will log errors to /var/log/mysql/error.log
mysqld is running as pid 7577
Finishes without an error message, but I don't see any way to enter a new password.
mysqld_safe
I tried this, but
$ sudo mysql -u root
ERROR 2002 (HY000): Can't connect to local MySQL server through socket
'/var/run/mysqld/mysqld.sock' (2)
$ ls -alh /var/run/mysqld/
total 0
drwxr-xr-x  2 mysql root   40 Mai 17 11:08 .
drwxr-xr-x 38 root  root 1,1K Mai 17 11:08 ..
I guess this might be an issue? What should I do?
Complete reinstall
I followed this guide to completely re-install mysql, but I run into the same issues.
Martin Thoma
  • 20,535
you can use this code
sudo /usr/bin/mysql --defaults-file=/etc/mysql/debian.cnf
ALTER USER 'root'@'localhost' IDENTIFIED BY 'password';
Apparently I was on the wrong track. I simply needed to login via
So not the -p option. No password required.
Martin Thoma
  • 20,535
MySQL 8.0 defaults to using auth_socket instead of passwords for root user, which means after installing mysql-server-8.0 you can simply login automatically with either:
sudo mysql
or
sudo mysql --user=root --host=localhost
...no need to specify the root user if you're already logged in as root to your shell. However if you are logged in as a different sudo user then you can specify that username instead (and no password) as long as the sudo user was added to MySQL as an auth_socket user.
The only time you need to specify a password if when logging in via TCP (e.g. @127.0.0.1). So if you try something like sudo mysql --user=root --host=127.0.0.1 --protocol=tcp then MySQL will prompt you for a password... but unless you setup a root@127.0.0.1 (TCP) user and password then you will not be able to login using that method.
Keep in mind it is now highly recommend to not setup a root TCP user these days, and instead create an alternative "maintenance" user (e.g. for phpMyAdmin) like admin@127.0.0.1.
Jesse Nickles
  • 462
